help.. no directional
Old Aug 9, 2022 | 06:10 AM
Peanut173's Avatar
Peanut173
Stage II
Exclamation help.. no directional
i have a 12 electra.. changed out grips and suddenly no left directional.. everything else on switch pack works but directional...
lights flash when turned off, dont think its the bulb? all wires seem to be connected..
thanks in advance
Old Aug 9, 2022 | 06:35 AM
Ultra103's Avatar
Ultra103
Go back to where you were when things changed. Make triple sure there are no pinched / loose wires in the left switch pack.
Old Aug 9, 2022 | 06:39 AM
Peanut173's Avatar
Peanut173
Stage II
checked everything a few times.. gonna replace bulbs and see what happens...
Old Aug 9, 2022 | 06:42 AM
Iceman24's Avatar
Iceman24
Everything was working fine before grip swap? Look closer as it doesn't take much to crimp/pinch a wire...seems too coincidental to be a bulb.
Old Aug 9, 2022 | 06:53 AM
Vernal's Avatar
Vernal
Disconnect the TSSM and see if you have 12V on W/V when you push the turn signal switch.
Old Aug 9, 2022 | 09:13 PM
btsom's Avatar
btsom
"The bulb" is singular, so if is it just one bulb doesn't work, it is probably the bulb. If BOTH bulbs don't work, it is probably an electrical problem. What is the flash rate of the turn signal indicator? Does it flash at all? Does it flash fast or at the normal rate? When my wife's car was a bit less than a year old, one of the turn signal bulbs failed. With a new bulb, all was back to normal. Bulbs are unpredictable, may or may not be your problem but they are cheap and easy to check and replace. Change the bulb and if it turns out not to be the bulb, you will have a spare when one does burn out.
You say the lights flash when you turn off the bike. Are you in a position to directly see the turn signal or are you just seeing lights reflected off the walls? If you directly observe that turn signal flash, then obviously you are correct, it isn't bulb but something else.
scryle205
Electrical/Lighting/Alarm
Apr 9, 2022 06:53 PM
Chase Dambski
Jul 8, 2019 05:43 PM
Chase Dambski
Jul 8, 2019 04:12 PM
Medicjaycook
Jul 20, 2012 11:14 PM
73novaguy
EVO
Aug 3, 2011 02:27 AM
