Tourpack removal kit...
https://www.advanblack.com/4-point-d...-14-later.html
https://www.advanblack.com/detachabl...-14-later.html
That'll bring you in at $277 plus tax, which is definitely cheaper than H-D.
I hope this helps.
If you really really really have to have one right now, you can find them at some of the online places for a chunk-a-change, like here. Or you can piece together the parts like above, but you'll need the harness for your TP lights.
Many guys use the CD light fillers, but others like th lights on the bags.
Stage 1: Bag lights to work as turn signals, new brake light with a plate bracket that puts the plate below the light, and a hidden antenna kit to move the antenna under the front fairing.
- This will allow me to remove the TP by just unbolting it from the bike. Four bolts should be simple enough after seeing some others post about it.
Stage 2 (if needed/wanted): Quick detach kit from HD for the tourpack.
- At this point I'll already have the turn signals on the bags, antenna and license plate moved so it should be a simple install.
But this is super simple to do on the Rushmore and later bikes... Like said just above, you're going to have to do something about the 1) AM/FM antenna, 2) turn signals that leave with tour pack, 3) have a place to mount your tag. Unplug 2 connectors (1 lighting & 1 audio), and unplug 1 or 2 antennas (am/fm & CB)... all connections are either under the seat or in front of the tour pack, and the tour pack is cleanly "unwired". Then just remove 4 bolts and the tour pack is off the bike.
I used a hidden AM/FM antenna (I used the HD one, and it has worked fine for me), so whether the tour pack is on or off its taken care of.
I used the slot lights (HD Electra Glo Keystones, CD Fillerz, etc), they all come with plug and play harnesses that'll work with or without the tour pack, so whether the tour pack is off or on its taken care of.
The tag mount can be the pain in the ***, depends on what you "want", I didn't like the "billboard" mount like that came with the kit, so I mounted a CD tag mount and a CD lit tag frame below the brake light on the fender and put a brake light lens on without a "tag window"... problem solved with or without the tour pack.
Then if you want the ability to take the tour pack off and put it back on easier (not having to mess with the 4 bolts each time), get the 4-point dock and tour pack mount... and you're just unhooking/hooking up the 2 connectors for the tour pack. HD, maybe inadvertently, is doing you a favor by pulling the "kits" until they get the "issue" resolved... now you'll get it set up with the components you'll actually choose
