My 89 Electra Glide Classic
I am new to the "Hundred Dollar" club. I purchased this bike a few months back from a buddy at work. I have a 88 VMAX that I was riding for years, and although I love the bike, it is not comfortable for long trips and I have always wanted more of a cruiser style bike. I am looking to do some modding and updating to the bike and I am looking for tips and suggestions. The stereo system I think I will leave as I do like having the handle bar controls. I did bring it some what in to the current century by using a tape cassette to aux cable and then using a bluetooth adapter. I would like to upgrade the speakers for sure. I am also thinking about getting the lower fairings with speakers in those. Although in my brief searchings this old of a bike doesn't like things in way of power consumption. Is there any upgrading I can do to the charging system? Maybe add a second battery somewhere? I do have some things I would like to take care of during the winter, carb rebuild, fix this slight oil leak I have. I would also like to upgrade lights and such to led.
https://drive.google.com/file/d/1f97...ew?usp=sharing
https://drive.google.com/file/d/1f-v...ew?usp=sharing
One other thing I forgot to mention. I am thinking of looking in to replacing the exhaust. The flange on the left exhaust pipe is pretty much almost gone. There is not much left. I would like to do a true one to one exhaust system. If that is the right terminology. One header to one muffler. I don't like the 2 in to 1 exhaust on these. It just doesn't look right to me.
Your stator is 32 amps max, 14 amps @1000rpm, and 29 amps @ 2900 rpm. Adding a 100 watt power amp would add 8.3 amps draw to your electrical system. You should be fine for speaker changes and a mild amp...
If you go with a mega power amp and/or start using heated gear, you could have a problem....
If you decide you want to become an electrical hog.... It's not cheap, but you can upgrade your charging system (I wouldn't even consider adding a second battery).
I am a fan of Cycle Electric stuff. They are a good company with a great reputation for quality electrical parts..
They make an upgrade kit, to a three phase/ 50amp system of their regulator, rotor, and stator.. You would need their #CE-81A-97 upgrade kit.
http://cycleelectricinc.com/ALTERNAT...ml#80%20series
There are cheaper upgrade kits out there, from a company called V-Factor (I have no experience with them) and Twin Power (I have used some of their stuff), but on something this major, IMHO, I would spend the extra money and go with Cycle Electric...
The exhaust you're talking about sounds like a true dual system. So the term "true dual" is what you'll want to use to search when looking for exhaust or parts.
I figured I'd ask here first before making a new thread. Would anyone here happen to have a part number or a good replacement for the brackets that hold the passenger backrest on the luggage box? One on the side has broke. I made a temp one out of some aluminum I had. But it must have been to thin because it has broke now.
