guys I'm new to the forum's thing but I'm at my wit's end with this bike.
i had to pull the primary off to replace the shifter arm, when i reinstalled everything, the clutch sits too far into the primary cause it to rub the housing. i torqued it to the correct specs but i cannot figure out why it is doing this any suggestions would be appreciated.
Thank you
The best suggestion I can give you is to post this in the Touring Section of the forum so people will give you real advice. Here, you're likely to encounter a bunch of BS remarks.
As far as your issue, my first thought would be to check the bearings the clutch hub rides on. Good luck.
The outer hub or the pressure plate?? If it's the pressure plate, try adjusting the clutch.. Did you take the clutch a part or leave the 6 bolts alone?
