I'm in the let the engine wind down in gear just until you're ready to stop, down shift at speeds as to not to cause the rear wheel to chirp, downshifting to fast will quicken the wear on the back tire.
Would rev-matching not remedy this? Or at least not letting the clutch out too fast.
Another one for using engine braking, while decelerating I downshift to match the speed/rpm and gear appropriate for the current situation. You never want to stop and have to be clicking down 4 or 5 gears. You may need to hammer on the throttle if something goes bad, and if you just coasting in neutral or wrong gear, the hammer down ain't gonna happen quickly. I also practice most every stop trying to slow the bike down with engine/clutch/rear brake til almost a stop before I have to put the foot down. It's good balance practice on these heavy bikes.
What's my name? Yeah I rev match and downshift. You'll be in a lower gear and have more control vs wearing out your brakes and being in a situation where you're dead in the water. Race car drivers will tell you higher rpms in a lower gear will give you more control too. What do you do when you come to a slow corner? Hold your clutch in and brake and then when you're out downshift?
I will sometimes coast with the clutch in, if its an open road with no traffic and Im just coasting up to a light.
Most of the time I downshift, blipping to match the revs. Like others have said you want to be in the correct gear to accelerate if necessary. Here is a good thread about that. https://www.hdforums.com/forum/touri...r-no-blip.html
I dont like getting rear ended. So I light my brake light up as Im slowing down, and especially when Im stopping.
Easy enough to downshift through the gears while doing this.
Good point, I will do the same if there is a car behind me
You have to watch yer 6
In a car I actually had to sit on my horn as the idiots behind me were talking to the people in the car next to them & coming up on me
As a safety factor tap the brakes to illuminate the brake light. When you are coasting down or engine braking there is no visible indication to the inattentive drives behind you that you are slowing. You don't need to actually apply braking force just get the brake light illuminated. I tap mine several times to increase the odds the following drivers will notice me slowing down.
I'm in the downshift crowd using the clutch. Just before you come to a stop, downshift to first. Use both front & rear brakes together, and once you are stopped, keep the rear brake on and your hands on the bars. Doing it this way makes sure you are always in the right gear should you need to accelerate out of a situation. Being an ex motorcycle instructor, this is what we taught new riders. Always remember the hazard coming up from behind you. You need to be able to accelerate or move out of the situation or at worst be ready to jump off the bike.
The above is the procedure for normal riding at traffic lights and for reasonable stop lengths. If it is at a longer stop, due to construction, train crossings etc, where you have a long line of stopped traffic behind you and you are going to be stationary for awhile, then most of us, would likely shut the bike off, and even put the side stand down. Circumstances in these types of situations will determine what you do.
