Exhaust
Old Sep 11, 2022 | 03:53 PM
OutlawFC222's Avatar
OutlawFC222
Default Exhaust
True duals to 2-1 is tuning required if it had already been tuned for the true duals i.e v&h dresser duals and cfr slipons. It has a heavy breather and had it when the shop dyno tuned it years back. I got a 2-1 sharkroad pretty cheap and want to get rid of the cackling cfr setup. 2013 flhx and will be adding the rivas .574 cams this winter. Just installed the man o war compensator since the comp eliminator was so f'ing noisy it sounded like something bad was about to happen lmao.
Old Sep 11, 2022 | 04:09 PM
Dseago1969's Avatar
Dseago1969
The change in exhaust needs tuned, but wait til the cam is installed, that’s another need to tune event.
Old Sep 11, 2022 | 04:37 PM
OutlawFC222
even If its been tuned with the dresser duals for 8 years or so lol? I gotta knock the heads off to swap springs and might add .030 headgaskets even though the local dealer tells me that's jerryrigging it but in all reality it's a way to bump compression. Circle track even us drag racers do it.
Old Sep 11, 2022 | 04:49 PM
Dseago1969's Avatar
Dseago1969
Changing from true duals to 2-1 or 2-1-2 is a tune event. AFR and the O2 sensors need it.
Old Sep 11, 2022 | 05:47 PM
johndoe297's Avatar
johndoe297
Waiting for the cam to tune would make sense, but you can get away with a canned tune from whatever tuner you have. The cam ideally needs a dyno tune.
Old Sep 12, 2022 | 10:02 PM
OutlawFC222
Well I installed the 2-1 exhaust. Guess what? It runs and a ton better than the previous dresser duals and cfr slipons. It does need a ****hair more fuel added in upper rpm range ie above 5k. Other than that I hit 105 in no time flat in 4 gears but had to let out of it due to noticing an undercover cop coming towards me 1/4 mile up the road lmao. My buddy who rides a 16 fatboy s said damn that sob moving instead of making a bunch of noise and going nowhere and I replied yep but 2nd gear it blew the tire off. Mind you I don't let off the throttle when I'm letting a bike eat. Speedshifting is my specialty.
DonnieM
Exhaust System Topics
Mar 12, 2019 10:20 PM
Sarge4
Sep 6, 2014 08:30 PM
mgmmgm
Nov 6, 2012 06:17 AM
vette03
Apr 11, 2008 09:02 AM
MiniMe
Apr 13, 2006 04:54 PM
