Hd keystone led filler lights
Recently added a detachable tourpak rack and the HD Keystone filler lights on a 2022 Road Glide Limited. I am having issues getting them to work in sequence with the tourpak lights, and sometimes they do not work (or only 1 will) at all.
Here's what is happening:
Ignition ONLY on, all lights come on. BUT if I start the bike the Keystones turn off.
Turn ignition on - and turn flashers on - then start bike and turn the flashers off - Everything works fine.
Turn off the bike, start it back up and Keystone lights are off again.
I have tried running flashers for 10 minutes, multiple types of BCM resets to "learn" the new signals, but no success. What am I missing here? All connections are good. Bike has less than 200 miles. HD Part # for the Keystones is 67801080
Any help greatly appreciated! Thanks
2014 and newer models with canbus / BCM electrical systems:
- Turn the Ignition on, but do not start the bike
- Turn on your 4 way hazards by pressing the hazard button on the controls
- Turn the Ignition off letting hazards run. If the bike has security they will flash 5 or 6 times and then pause. This is expected. They will go back to flashing normal hazard mode
- Let hazards run 1-2 minutes
- Turn the ignition back on
- Turn Off the hazards
- Turn the ignition off and then back on
- Check the function of both turn signals
