Street Glide 103 will not start
Old Oct 26, 2022 | 07:38 AM
MarkWa's Avatar
MarkWa
Originally Posted by Vernal
1 = 3C GN/O
2 = 4c Y/GN
3 = 4D W/BK
4 = 3D BE/GY
Measure voltage to ground not wire to wire.
Pull the relay and turn the Ign on and run switch to run. BK/W and BE/GY should have 12V to ground.
Pull the fuse just left of #2, should be the fuel pump fuse, and see if it's blown. If not reinstall the fuse and relay then ground the black lead, touch the red lead to the little metallic spot on the top of the fuse next to the 5 in 15, crank the engine and see if you get 12V.
Everything works as You say, 12V on fuse and relay
Old Oct 26, 2022 | 07:44 AM
MarkWa's Avatar
MarkWa
1 = 3C GN/O
2 = 4c Y/GN
3 = 4D W/BK
4 = 3D BE/GY
Checked voltage when cranking between AD and AC and getting 5.5V on both
Old Oct 26, 2022 | 09:38 AM
Musician's Avatar
Musician
'08 FLHT. Had a similar problem last summer. Disconnected the fuel line from the tank, then reconnected, no help. Disconnected it again, and cranked the engine over with the line off. Reconnected the line, and it fired right off. Did that several times, no idea why. Hasn't done it since. Replaced the fuel pump, filter and lines about 3 months earlier, and had zero starting problems. Acted like a vapor lock on my old carbed bikes in the summer.
Old Oct 26, 2022 | 10:48 AM
Vernal's Avatar
Vernal
Mark when you post a picture of a connector tell us which connector you're looking at. Then if you take readings, I think you read A-D and A-C state why and what you expected to see. Do you have 12V to ground on the Y/GN, (A), at the coil while cranking?
Old Oct 26, 2022 | 11:10 AM
MarkWa's Avatar
MarkWa
Yes there is 12V on Y/GN while cranking
just disregard the other measurement I don’t know what I’m up against 😂
Old Oct 26, 2022 | 11:16 AM
Rounders's Avatar
Rounders
Because I am a moron, one time when replacing a CPK I put it backtogher wrong and pins were not lined up.
I find it interesting no spark and no fuel. If you had spark, I would say put some gas in plug just to see what happens.
Did you have both plugs out when testing spark? There was talk if delphi need a plug in to see compression. I tested it, and now I can't remember if true.
Old Oct 26, 2022 | 11:23 AM
MarkWa's Avatar
MarkWa
Yes both plugs are in testing on spare spark plugs 2 of them brand new will look again at CPK connection but already checked twice uhhhh
Old Oct 26, 2022 | 11:43 AM
Vernal's Avatar
Vernal
Having 12V on the Y/GN proves the CKP is giving the ECM a signal or it would not ground the system relay.
Old Oct 26, 2022 | 11:50 AM
MarkWa's Avatar
MarkWa
could this lead to ECM being bad ?
or what else prevents ECM from sending signal to the coil
Old Oct 26, 2022 | 05:20 PM
Vernal's Avatar
Vernal
Did you use OEM Spark plugs?
