had this happen on my gixxer. got it home exactly like architect described.
I wonder if the cable showed signs of fraying at the perch prior to snapping.
guess I'll put this area on my check list.
When they break at that point, it's typically dues to lack of lube on the pivot part of cable end in the lever or improper routing of the cable to the lever perch where the cable comes in at an angle and not straight.
A friend had that happen many years ago. We cut and peeled the cable sheath back to expose the cable and clamped pliers on it so he could pull the clutch and shift gears. Made it home with no problem.
Cables do need lube other than the ends. They are almost entirely covered in some type of plastic.
This bike is stock. So I dont see it being routed improperly
I've often wondered how you can lube it effectively with that plastic covering the cable? It doesn't seem to me the lube would make it passed the plastic sheath.
I give a good dose of lube to each cable then blow compressed air to force it all the way down to the ends. Once they drip there, clean up and you're done.
I've seen that tool before but I still don't see how that allows the lube to get UNDERNEATH the plastic sheath and actually lube the cable. For all I know the lube you're squirting in is running down the OUTSIDE of the plastic sheath. Maybe I'm wrong.
The tool seals around the casing. There is a small hole on the side of the tool that you spray the lube into via the included tube. The lube flows into the casing. Some does come out externally (it's a messy operation no matter how you do it), but most flows into the sheath.
Edit to add: you have to remove the cable from the handle so you can access the open end.
It probably not cable lube that killed the cable. It's lack of lube at the attachment to the lever. It forces the loop to flex the cable right where the loop forms. Very common issue. Even with the old barrel ended cables.
