UltraClassic 6th Gear Useless Below 70
My '08 at 55 mph would be running under 2000 rpms in 6th gear.It don't feel right til 65mph.
There's been some mention about "keeping it in the powerband" in this thread. I'm personally usually out riding for the enjoyment of it, to "smell the roses", as they sometimes say, not to pass everything in sight. I simply don't need all the power the engine can make, or anything close to that, normally. So I tend to stay at the low end of the powerband intentionally. I don't lug, but keeping rpms low is a good thing, for several reasons; it minimizes wear on internal moving parts, as well as minimizing noise and heat. It's not hard to hear if the engine is happy.
And not to confuse the issue any more than it already is, let's acknowledge when we're tossing all these speeds around here, that a the speedo on a stock bike is almost guaranteed to be reading too high. Mine reads 4mph too high at 60mph. So, if I'm riding in 6th gear and indicating 60 mph, I really only going 56 actual mph. Wonder if HD took that into account when they published the gear change speed table in the manual.
Hogback
It has 6 gears. You are supposed to shift into the best gear for the riding conditions. It's not an automatic tranny in a car. It has a clutch and gears. You are the brain.
ACT LIKE IT.
I've read so many posts about this and I've read my manual and I've learned not to lug my motor as best that I can. I try to make sure to be close to the right rpm's before shifting up and I shift down when needed.
On a few occassions I've been asked "How's that 6 speed, do you have to downshift on hills?" I'll reply "sometimes I do" in amazement that someone would think that you can just ride in 6th once it's there and forget about it.
I like my bike to be in the power range so it's responsive, especially in traffic so I don't see 6th gear until I hit the highway anyway.
Again, didn't mean to offend, Ya'll ride safe in whatever gear ya choose!
The shop installed a race tuner, screamin eagle slip ons and an new air cleaner. The bike was like a new bike and the performance went way up along with the driveability. 6th gear was now usable on flat ground and in the foothills riding one up. I still believe that the gear ratios are too high for a touring bike with its weight. I then had the shop install the Harley 103 warranty kit with cams and the bike is a lot better except for the gearing issue.
Baker has a 6F6 kit for the tranny and he recomends a smaller pulley (1 tooth) on the tranny and a shorter belt from Harley. This is supposed to increase the engine RPM by 200 in 6th gear. I believe this will solve a lot of the lugging issues people have by reducing the load on the engine in all gears at all RPM. This is a long stroke engine that should lug better than a 88 and it does not because it is impropperly matched to the tranny.
On my last road trip we went 850 km in one day and we went thru the mountains with the temperature ranging from 45 degrees to about 90 degrees and the bike ran great just don't use 6th gear unless on flat ground or down hill. The clatter and lack of power sucks. I ran mostley in 5thgear and my mileage was about 54 mpg. That is with an imperial gallon not american.
The5th gear whine is awful on mybike and the clatter in 4th and 6th sucks as well. When the bike is cool it makes little noise at all but when it reaches operating temp it is really annoying. The first hour of any long trip I really enjoy my bike but again stay out of 6th.
My bike runs 2600 rpm at 100km per hour or about 62mph in 5th gear.
I have to say that the dealer and Harley have been great to this point and I am very satisfied with the progress we have made.
I am having the IDS installed and am adding the JRS Originals to help with the heat.
Later.....
Hack
The only 6 spd I've ridden was a demo Street Glide. I agree, I would not use 6th until 70 mph.
My Heritage averages 40 mpg by the way.
