Am I crazy?
The bars on my RK are 10 mini-apes (from HD)
kinda low. They work best when Im a bit leaned forward and on top of the bars. Really made for push to lean riding it suits the curvy backroads I enjoy riding.
One of the folks I ride with has 14 apes on his SG. We ride through the same counties, but he prefers the highways. The highways here are scenically beautiful and you get further from home! He has a more leaned back posture on the bike.
My setup is more comfortable & enjoyable for the routes I choose his setup works better for his preferred roads.
After couple hundred miles your body will tell you what your issues are. For me the stock bars hurt my wrists and shoulders, but they too felt just fine in the showroom.
Bars are tough, everyone's ergos are different and it's not an easy/cheap swap (at least for me) if you don't get it right the first time. That said, when you do get it right it makes a huge difference.
I bought my bike with 10 inch Twin Peaks already installed. Those had like 4 or 5 inch pullback and I was always reaching for them. So I changed to FBI 12 inch bars with almost 12 inch pullback. Don’t get me wrong, I like them and they are comfy, but I really think that stock bars are more comfortable! Not to mention, my jacket doesn’t ride up because my arms are not in Frankenstein position lol.
Anyone else ever went back to stockers???
I am 5 ft 10 inches tall with an average arm length…..I never had any issues with stock bars on any bikes. My current ‘15 Ultra came with the LA bars, which worked well for the previous owner, but he was 6ft 3in-ish…..Last week I replaced the LA bars with the FBI 11” Reduced Reach bars (34 in wide with 12 in pullback VS the FBI 12 in bars which are 36 in wide with 9 in pullback) and i immediately knew i made the right choice - for me. I only got about 30 miles on the bike since the new bars, but i waited too long to make the bike ergonomically right - for me.
So - make your bike right for you - ASAP. If that’s with stock/oem bars, who cares!
If you like a different non-oem style of bars, like apes, or whatever, do a lot of research and reading, and use the stock/oem measurements and dimensions and compare to make the best choice for you. Visit as many area dealers to see if you can sit on bikes with various bars that might work for you if you can. The importance of properly fitting bars -for you- cannot be overstated. For me - bar dimensions were narrowed down to the Khrome Werks 1-1/4” 2+2 Sweepers or the FBI 1-1/4” - 11” Reduced Reach - I liked the style of the FBI bars better….
The other thing to note - the shop I had remove the LA bars and install the FBI bars found several things NOT done correctly by the previous shop that installed the LA bars - not enough tie-raps were removed to free-up slack, which stressed several wires to the point of needing repairs - so good thing I had the FBI bars professionally installed - future problems avoided!
Good Luck! Another Upside - if you want to go back to oem/stock bars, should be able to get some cheap if not free - then sell the 10” bars you remove!
Personnally I think they are fad. maybe accentiated by fly by wire making easier to change bars.
