AN Big Sucker
Old Aug 20, 2007 | 02:13 AM
Qball's Avatar
Qball
Default AN Big Sucker
Looking at the Big Sucker for my EG. Have SE slip ons, but didn't do the air cleaner. Have a Cobra fuel processor installed so I can easily change the fuel management. Curious on how many installed the Stage II Big Sucker over the Stage I. Should I be concerned with anything when making the choice?
Old Aug 20, 2007 | 02:15 AM
dawg's Avatar
dawg
Default RE: AN Big Sucker
I had the Stage1 on my eglide and plan on putting it on my Ultra. I even had a Stage 2 motor on my eglide and all was well. If it were me with your set up I would just go with the Stage 1
Old Aug 20, 2007 | 03:39 AM
kjunguy's Avatar
kjunguy
I have the AN Stage 2. Jamie @ Fuel Moto told me that preformance on the 1 and 2 are about the same. If fact, he said there was no reason to change my map when I switched from the 1 to the 2. I switched because I liked the way the 2 looked with a flat cover (see sig pic). If you do decide to go with the stage 2 remember that it is a little thicker and will stick out more than a standard A/C. If you have the 3/4" or 1" floorboard extenders installed you should be Okay.
Hope this helps.
Ride Safe, Ride Hard.
Old Aug 23, 2007 | 11:06 PM
Qball's Avatar
Qball
Anyone use anything else other than the Screaming Eagle? I looking for a picture and your thoughts. I like the Stage II big Sucker as well as the Kuryakyn Hypercharger Styles. My concern is comfort on the leg. I am running the 3/4" floorboard extenders. Thanks!!
Old Aug 23, 2007 | 11:55 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Stick with the Stage 1 - The 2 sticks out a bit more... & It's more then you really need - Unless you plan of doing the 103 -110 kit
Cupcake1973
Feb 3, 2011 12:01 PM
lomogda
Jan 23, 2011 09:11 AM
MovedtoSyracuse
Aug 28, 2007 08:14 AM
gdbro4
May 13, 2007 05:45 PM
docpage
Exhaust System Topics
Aug 22, 2006 09:21 AM
