Adding fender extension
Old Feb 2, 2023 | 07:43 PM
snapring6r's Avatar
snapring6r
Default Adding fender extension
So, I finally scored a factory rear fender extension for my 2013 RK. I'm not wanting to drill holes in my fender to attach. Does any one know of a good way to attach that has had good success? Thanks
Old Feb 3, 2023 | 07:16 AM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
I put one on my 2020. I debated on how to attach it, some use 3m tape, success with this method varied. I ended up purchasing the factory mounting plates and hardware. Drilled the holes and put it on, no issues.
Old Feb 3, 2023 | 08:21 AM
Oko's Avatar
Oko
If you can "buck up" and drill the holes, make sure you coat the inside of the holes with either touch up paint and or clear. I use several coats and rubber grommets.
It took me a while to wrap my head around doing it. You'll be fine.
brent1024
Sep 27, 2017 07:10 PM
kungfookielbasa
May 29, 2014 05:00 PM
heavyd460
May 13, 2013 08:07 PM
BLKnCHRME09Deluxe
Oct 25, 2010 05:08 PM
diiulio
Aug 13, 2006 10:32 PM
