Detachables lock with tour pack
Old Feb 23, 2023 | 06:06 AM
MyFavRk's Avatar
MyFavRk
I sure can , I have the tour pack off while I do maintenance on the bike , try to get to it later today .
702's comment reminded me of this . Both locks came with 2 keys , one was shorter than the other , which makes it impossible to use the longer one on the left side of the tp , unless you cut it shorter .
Honestly , I think the main purpose of HD selling two locks in the kit , is to put one on each of the quick release systems , eg : rack / backrest , you only need one lock for each system . I don't think it's necessary to put both locks on the tour pack , but if it's doable , why not . The only issue issue here , is having to cut the longer key to be able to use it as a spare .
Old Feb 23, 2023 | 07:52 AM
Ssitruc's Avatar
Ssitruc
You can use them on tour packs, 2-up position... if your talking about these
https://www.harley-davidson.com/us/e...E&gclsrc=aw.ds
See the installation instructions, it tells you how to put it on for different models and years
Touring
2009 - Later
Two-Up Tour-Pak Rack - See Figure 3, Outer Right Installation
You're just "supposed" to use one for each accessory. I think if you put both on one accessory, on one side it will spin to lock the opposite direction than normal. Only thing I have seen is that they can be a problem on Rushmores on the Solo Tour Pack Rack, due to the orientation when they are locked makes it tough to get the key into the lock to unlock them... but it can be worked around... See Post above.
Old Feb 23, 2023 | 10:45 AM
MyFavRk's Avatar
MyFavRk
Ok , the verdict , you can fasten the locks on both right / left side , however , only the short key will work , as pictured on both sides . The longer key can be cut short , if you need a spare at some point , haven't done it yet , but plan to in case of emergency . Like mentioned , I don't think 2 locks are necessary , but added security is not a bad thing . Left side
Right side
jneub1
May 28, 2022 11:18 AM
zproud
Oct 26, 2013 08:27 PM
scooty
Oct 11, 2007 07:19 PM
thumper05
Jun 21, 2007 05:43 PM
retcop
Product Reviews
Apr 5, 2005 03:00 PM
