Rough idle backfire
Old Mar 2, 2023 | 08:02 PM
DWMauney's Avatar
DWMauney
Stage IV
Default Rough idle backfire
I have a 2000 Ultra Classic. It is having mutiple issues. Ran great. Went out for lunch. When I tried to start to give home all these issues started.
high rough idle
backfiring
Tach not working
Check engine light on
I have did the following repairs to no avail
New spark plugs and wires
new gaskets and clamps on throttle body
new gaskets on air intake
New air filter
Tried to check codes. All banks say clr when in diagnostics
Any ideas would be helpful
Old Mar 2, 2023 | 10:41 PM
Black Ultra's Avatar
Black Ultra
well, what could have happened while you were at lunch? My first thought would be vandalism. Like maybe something in the fuel, or a cut wire. If i were in your shoes, I would remove the tank and wash it out, replace the fuel filter and look hard for any wires that could be easily accessed.
I hope I'm wrong. Good luck.
Old Mar 3, 2023 | 08:58 AM
euchre98's Avatar
euchre98
Fuel injected bike? If so the Marelli system that was used then is famous for intake leaks.
Old Mar 3, 2023 | 09:47 AM
BrokeWinger's Avatar
BrokeWinger
Did you get gas?
Old Mar 3, 2023 | 12:28 PM
DWMauney's Avatar
DWMauney
Stage IV
I replaced the gaskets and flanges. After installing also sprayed cleaner around while bike was running. No intake vacuum leaks.
Old Mar 3, 2023 | 12:30 PM
DWMauney's Avatar
DWMauney
Stage IV
Originally Posted by BrokeWinger
Did you get gas?
yea earlier in the day. Ran a half tank through with no issues. Got more gas on the way home. Another half a tank ran through. Still rough.
Old Mar 3, 2023 | 07:37 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you have a crank position sensor in the front of the engine, unplug and reconnect. Or with that year the Crank position sensor maybe in the nose cone on the cam chain cover. Hopefully some with the knowledge of this CPS will chime in and walk you through the diagnostics. The CPS triggers the ignition circuit to fire the plugs.
Old Mar 16, 2023 | 06:17 PM
DWMauney's Avatar
DWMauney
Stage IV
Just replaced this also. Still to no avail
Old Mar 16, 2023 | 10:21 PM
Black Ultra
Have you tried some fuel system clearner? maybe a partially clogged injector? Maybe a new fuel filter?
Old Mar 17, 2023 | 01:06 AM
kojak's Avatar
kojak
high rough idle
backfiring
Tach not working
New air filter
if the check engine light is on, there is a malfunction detected by the ecm. On the earlier EFI models, the dealer can pull codes that won’t show on diagnostics from what I understand. Good luck on getting the problem resolved.
mmeddle1
Apr 2, 2012 04:05 PM
rab474
Oct 9, 2011 02:12 PM
fishbust
Sep 27, 2011 10:38 AM
hawc929
Welcome Area Only
Apr 26, 2011 05:54 PM
user 6485939
May 17, 2006 09:36 AM
