2017 Road Glide Error Code p0327
Old Mar 20, 2023 | 07:39 AM
DaBizz68's Avatar
DaBizz68
Question 2017 Road Glide Error Code p0327
I have a 2017 Harley Davidson Road Glide Specail. For the past month I have been getting a check engine light Error code P0327.... googling and looking researching one of the main diags have suggeted a knock sensor. I am contiplating changing my spark plugs and the knock sensor to see if this fixes the issue. I am the only owner and believe and I can't recall ever having my spark plugs changed. I have a Fp3 fuel pack on my bike that I thought could be causing the issue. I bypassed it re-flashing my ECU with the factory map..... cleared the codes... check engine lights goes away I let bike idle for awhile one time and the other time test road and sure enough the check engin elight returned. I'd really would hate to take to the Harley Dealership as I know they will charge me out of the wazoo for a simple fix.... Would you all start with changing spark plugs and it says bank 1 knock sensor to see it that fixes it? I have jacked my bike and checked every wire I could get to to make sure nothing was loose. BTW even with the check engine light on the bike still ran strong and sounded normal... I am just don't like riding my Hog with any check check engine lights on. Light it yellow btw if that helps any. Any and all input is welcome and appreciated.
Old Mar 20, 2023 | 07:56 AM
GalvTexGuy's Avatar
GalvTexGuy
I guess the obvious question is which brand gas and octane are you using?
Old Mar 20, 2023 | 08:07 AM
DaBizz68's Avatar
DaBizz68
Always 92,,,,, Usually Chain Brand Gas stations Shell / Racetrack / Mobile
Old Mar 20, 2023 | 08:34 AM
r0de_runr's Avatar
r0de_runr
Easy to try new oem plugs and new oem plug wires.
Old Mar 20, 2023 | 08:41 AM
702's Avatar
702
If I had a fault code telling me about a knock sensor issue, after checking wiring I'd replace the knock sensor.
Cle_rider's Avatar
Cle_rider
Why change a part until it's tested to know if the sensor is actually bad, whether it's wiring or even whether you have a dying battery. If happens regularly, that would rule out bad fuel. Can you swap the sensors from one side to the other to at least see if the problem migrates with the sensor? From the parts fiche looks like its the same part number for both sensors. If you haven't changed the plugs, probably a good idea regardless.
Old Mar 20, 2023 | 08:49 AM
smitty901's Avatar
smitty901
Some 2017 RGU were known to have a plug wire rubbing causing wear. This is 2023 ,it may be a good idea to do the plugs anyway. Check wires.
Old Mar 20, 2023 | 04:24 PM
rideonva's Avatar
rideonva
According to Harley’s maintenance schedule spark plugs should have been changed at least twice - I’d start there, cheap and easy to do.
HOGILAC
Engine Mechanical Topics
Dec 29, 2017 11:16 AM
skizman
Jun 29, 2017 02:16 PM
dgretz
Sep 1, 2009 02:39 PM
HogMan
Oct 9, 2008 10:00 AM
smokeybud
May 26, 2008 10:13 AM
