Draining Battery
Old Apr 14, 2023 | 06:59 AM
MyFavRk's Avatar
MyFavRk
Agreed , sounds like you need a new battery , take it in and have it load tested , most places will do it for free , but honestly I would replace it . You'll get a few bucks for your old one , core value .
You could test your battery , volt meter , neg on battery terminal , pos on starter , hit the starter button , if your seeing less than 10v , time for a new battery , providing your cables are in good condition , also clean and tight .
Old Apr 14, 2023 | 07:07 AM
Uncle Larry's Avatar
Uncle Larry
As stated above... "take it in and have it load tested , most places will do it for free" ... This would be step number one even if you have a battery charger ... A load test will give the health report of the battery
Old Apr 14, 2023 | 07:10 AM
IronAss's Avatar
IronAss
Check your battery cables to insure they have good solid connections on both ends or aren’t broken or worn through.
Old Apr 14, 2023 | 03:50 PM
MBenbrook's Avatar
MBenbrook
5th Gear
I tried to jump start it today and it would try to turn over then act like the battery was drained. I was using my car to try to jump start it. When I would hook up the jumper cables it would show 14 volts but as soon as I hit the start button it would drop down to 3-4 volts even with the jumper cables hooked up to it. Are you still thinking the battery, or something else? I'm stumped.
Old Apr 14, 2023 | 03:58 PM
Rounders's Avatar
Rounders
Originally Posted by Screamin beagle
you're not serious are you? So no one should bother checking codes anymore? Even you said its free and easy so why wouldn't you do that first thing? It only tells you what's wrong and it even tell you the freaking part number for the bad part....yeah you're right...waist of time lol
No its easy to do, you can go in from the face. But if check engine light doesn't come on, I am not sure if does much good. To be honest they have never helped me, not that I am against checkibg. But when it comes to the charging system, there are some quick checks with a meter I do first.
I am surprised more of you don;t own a load tester.
Years ago people did consider load testing a destructive test, but not any more.
Old Apr 14, 2023 | 04:23 PM
commander47's Avatar
commander47
Probably the battery.
If it is older than 2 years you are probably on borrowed time.
Simply checking how to is here:
Old Apr 14, 2023 | 04:25 PM
MyFavRk's Avatar
MyFavRk
Thinking this through , you are connecting the car battery from terminal to terminal , ( Bat to Bat ) . Try to jump it straight to the starter ( pos on starter , ground to frame ) , does the starter engage or not .
I would still have the battery load tested . Also , check the cables , broken or corrosion inside the jacket could be the culprit .
Possibly a bad solenoid inside the starter ?? I doubt it , because you said the voltage is dropping to 3-4v when starter is pressed . You can remove the solenoid and clean it with emery cloth , but this is not nearly as good as if you were to replace the parts , you can purchase just the kit . A weak battery can cause pitting etc , in which case , cause poor connection . Guessing this is not your case .
Old Apr 14, 2023 | 05:15 PM
Cle_rider's Avatar
Cle_rider
Not all codes throw an MIL, but some circuits like abs are more sensitive to power issues so something like an abs module will throw a inactive code for power loss when something is sapping the power, like a bad starter. Any modern vehicle, you start with the checking for codes.
Sounds like something with the starter. Bad brushes? Loose connection? frayed wire? Have you tried tapping on the starter when you turn it over?
Old Apr 14, 2023 | 05:35 PM
702's Avatar
702
If your battery is below a certain level jump starting it won't work, the starter will just click. Based on what you've written here, it sure sounds like a bad battery to me.
Old Apr 14, 2023 | 06:18 PM
ybnorml's Avatar
ybnorml
And to think he's known as the brainy one ......
