Draining Battery
Old Apr 14, 2023 | 06:19 PM
YZR's Avatar
YZR
Everyone is telling to get the battery load tested and you're still stumped?
Old Apr 14, 2023 | 09:41 PM
im's Avatar
im
A very dead battery can act as an additional load/drain when another battery is used to jump start (terminal to terminal).
Do not jump from another vehicle that has the motor running.
From a distance it reads like several others have reported.
You must remove the battery and have it load tested.
Also, trying to jump start a totally dead or shorted battery could cause significant damage to your bike and the donor battery.
3 to 4 volts is beyond dead.
Old Apr 15, 2023 | 01:55 AM
MBenbrook's Avatar
MBenbrook
5th Gear
Ok sounds like I need to get a new battery. I'm sorry to be a bug but I was just trying to rule out any other possibilities. I thank all you brothers for every bit of information you have given me. I will get a new battery and see what happens. Hopefully my next post will say, "thanks everyone that was the problem," Safe and happy riding to everyone, I will let you all know what happens. Thanks again.
Old Apr 15, 2023 | 02:01 AM
MBenbrook's Avatar
MBenbrook
5th Gear
Originally Posted by MyFavRk
Thinking this through , you are connecting the car battery from terminal to terminal , ( Bat to Bat ) . Try to jump it straight to the starter ( pos on starter , ground to frame ) , does the starter engage or not .
I would still have the battery load tested . Also , check the cables , broken or corrosion inside the jacket could be the culprit .
Possibly a bad solenoid inside the starter ?? I doubt it , because you said the voltage is dropping to 3-4v when starter is pressed . You can remove the solenoid and clean it with emery cloth , but this is not nearly as good as if you were to replace the parts , you can purchase just the kit . A weak battery can cause pitting etc , in which case , cause poor connection . Guessing this is not your case .
https://youtu.be/1eKeEgpJtZI
The starter will engage just can't get enough power to turn the engine over. Guess I will get a new battery and see what happens.
Old Apr 15, 2023 | 02:37 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If you really suspect the battery you could remove it, connect the car battery and see what happens.
Old Apr 15, 2023 | 03:55 AM
Jackie Paper's Avatar
Jackie Paper
MBenbrook, got a lot of good advice here. Just as a suggestion, make your next new post over in the new member welcome area and say hello.
Just in case, Welcome. Hope you enjoy your ride here_______
Old Apr 15, 2023 | 04:42 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Have the battery load tested or replace it.
Put the jumper cables away, they are not a troubleshooting tool.
Old Apr 16, 2023 | 05:52 AM
Ron750's Avatar
Ron750
Don’t jump your bike with a running car. I’ve read threads on here where that damaged the ECM. If your battery tests ok, check your grounds. I had your symptoms, it was a bad ground. Check both end of the battery cables not just battery side.
If I want a full charge on a bad battery I use a 2 amp trickle charger. I have a newer one that’s “smart” it charges at a higher rate but slows down as it approaches full.
Battery tenders won’t charge a discharged battery to full charge.
Old Apr 16, 2023 | 05:29 PM
MBenbrook's Avatar
MBenbrook
5th Gear
To start off with I would like to thank everybody for being patient with me and giving me their advice. I went today and bought a new battery put it in and she fired right up running great thanks everyone. Happy and safe riding to you all
Old Apr 16, 2023 | 10:15 PM
im's Avatar
im
Make sure to measure voltage at battery terminals with a digital meter.
Maesure:
At rest
Cranking
and then Hugh idle
Reason:
To confirm that charging system is OK.
