From a Road King to ??
Old Jun 9, 2023 | 09:56 AM
  #71
Sirgilbert357's Avatar
Sirgilbert357
Originally Posted by Jshopes
no, definately not, and i have no idea if theyre the same. most aftermarket companies probably run 14-22, but again, i have no idea. if youve never touched your air shocks they probably dont have any air in them. you can get a bicycle suspension pump at walmart that does the same as the hd pump, for a good bit less money, just dont use a compressor. those shocks dont take much to pressurize
OK, good to know. I don't want them any firmer, though...lol. They are already pretty stout. I'm 6'3" and weigh 185. Probably not your average Harley rider weight, LOL. I'm guessing stock setups are tuned for more weight in general, especially on the large touring bikes.
Old Jun 9, 2023 | 10:39 AM
  #72
Jshopes's Avatar
Jshopes
eh, idk. if theres nothing in them you could be bottoming out too easy. 180 should be in their range.
Old Jul 3, 2023 | 03:33 PM
  #73
bunkeru2k's Avatar
bunkeru2k
4th Gear
Just putting heavier weight shock oil in the stock shocks helped mine out a bunch. I am 190 lbs and run 6-8 psi in them. I also modified them to have a direct input with one single line running from one to the other rather than extra points of failure they come from the factory with.
Old Jul 4, 2023 | 11:15 AM
  #74
danaezabail's Avatar
danaezabail
hello from a former FtW neighbor... If you can make your way over to the dealer on airport freeway, ask for Chad. He was BEYOND helpful when I was choosing my RGU. I didnt know if I wanted a limited and his expertise put me on the right bike..
Old Jul 4, 2023 | 02:39 PM
  #75
Sirgilbert357
Thanks I will keep his name in mind in case that dealer has a bike I become interested in.
Old Jul 4, 2023 | 02:41 PM
  #76
Sirgilbert357
Well, something might be wrong with my pump...when I connect it to the shocks, I can't get the pressure on the gauge to go up. So, not sure what is going on there...not gonna bother to trouble shoot, It's been fine this long, I can ride it a bit longer as is until I get a new bike (which I will then be doing a full suspension on right away).
GreenMonster
May 8, 2022 08:03 PM
newrider66
Oct 30, 2019 10:52 PM
thexravenx
Jan 8, 2019 01:39 PM
ChrisHo
Milwaukee Eight (M8)
18
Jul 29, 2017 06:23 AM
SportyPig
Oct 23, 2006 05:10 PM
