07 Ultra Tail Light Fuse Blows with Passenger or Luggage
Old Jun 4, 2023 | 06:16 PM
blbowers's Avatar
blbowers
1st Gear
Default 07 Ultra Tail Light Fuse Blows with Passenger or Luggage
Swap the blown fuse out and I have tail lights. Add luggage and a passenger, the fuse blows. All other electronics and lights are fine (I have brake lights, turn signals, front lights, etc....just not the full-time running lights). So I'm assuming there's a short and I'm also assuming it's likely due to overloading the trunk on road trips. I want to trace this short in the most efficient, logical manner possible. Has anyone traced down a similar short (tail lights)? If so, tips would be helpful. Thanks in advance.
Old Jun 4, 2023 | 06:42 PM
07UltraGuy's Avatar
07UltraGuy
Sounds like the rear wire harness is shorting against the fender when the rear tire rubs it.
If the bike has ever been lowered, then it is a pretty common failure mode; the tire rubs through the harness and exposes the wires.
Old Jun 5, 2023 | 09:29 AM
dasmotorrad's Avatar
dasmotorrad
I agree with 07UltraGuy.
Old Jun 5, 2023 | 09:35 AM
glasspilot's Avatar
glasspilot
My bike is just a year older than the OPers.
Blbowers, Remove your seat. Just aft of the battery you'll see the harness that heads back to all the lights. Trace back, I'll bet at some point you'll see a worn area.
Good luck!
MoJo Rider
Electrical/Lighting/Alarm
Sep 27, 2013 03:49 PM
FFLETCHER
Sep 11, 2012 07:07 PM
C.H.L.
Apr 13, 2010 11:35 PM
skoto1
Oct 29, 2009 08:14 AM
xtrout
Nov 22, 2008 03:30 AM
