front brake squeel
Old Aug 24, 2007 | 09:59 AM
SG Mike's Avatar
SG Mike
Default RE: front brake squeel
Dealer swapped rotors on my SG and squeal is gone most of the time. Get floaters and replace pads.
Mike
Old Aug 24, 2007 | 10:12 AM
debay's Avatar
debay
I got the squeal and my rotors where swaped , IWill have to try Lyndels when i need new shoes
[hr]
Old Aug 24, 2007 | 12:16 PM
LeeFLHX's Avatar
LeeFLHX
Everyone pretty much covered the options. Don't know about the WD 40 one however.......
Got back from Sturgis a few weeks ago and had been doing a fair amount of riding on "treated" gravel roads in and out of the campground and developed a squeal. Used my pressure washer to spray the brakes and then a good amount of brake clean to seal the deal. No more squeal.
As someone stated, Harley will do the swap on the front rotors if a good cleaning doesn't fix the problem.
Lee
Old Aug 24, 2007 | 01:59 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
My 06 front brakes had the squeal, dealer did the rotor swap and now they only make noise when I'm backing up.
Old Aug 24, 2007 | 02:17 PM
txphoneman's Avatar
txphoneman
When you buy a brake pad kit at the auto parts store, they give you a little package ofgrease to put pn the pads whei installing.
If you go to the auto parts store, they might give you a pouch. place a little of this grease on the pad. go slow and work it in untill the brake stops at normal. thThe pad will last longer and the squeel is gone. Cheap fix.
Old Aug 24, 2007 | 02:50 PM
ken thompson's Avatar
ken thompson
The Schlong Man
Apply a bit of pressure to the front brake lever. Mine makes a constant squeal as well that can only be heard when going slow. I goes away if I pull in the brake lever a wee bit (not enough to engage the brake).
Old Aug 24, 2007 | 06:38 PM
nedster's Avatar
nedster
I read somewhere that the pins that the pads rest on kinda get krusty, try removing a cleaning them. Worth a shot!
Old Aug 24, 2007 | 06:48 PM
dionne51's Avatar
dionne51
Ditto on the rotor swap, had mine done at 500 or so miles on my '07 and haven't heard anything in the last 6000+ miles.
Old Aug 24, 2007 | 07:15 PM
Neckball's Avatar
Neckball
Have you noticed the 2008 models have a different pattern cut out in the rotors.
All Aces
May 21, 2017 08:29 AM
hdman6
Feb 29, 2012 12:04 AM
fixedmlc
Aug 25, 2009 11:11 AM
mitcht
Aug 10, 2007 02:35 PM
genedjr
Aug 3, 2007 11:49 AM
