Is this normal?
Old Aug 10, 2023 | 08:48 PM
UltraSeattle's Avatar
UltraSeattle
6th Gear
Wow, thanks for all the great insights. Really appreciated.
Paul, no... there's been no increase in lifter noise, so that's reassuring for me. In fact, I changed the spark plugs and, with the fresh new oil change, the motor has never sounded smoother/quieter.
I'm not familiar with how to do a manual reading of the oil pressure, so I'll take it to the stealership and see if they can give me a manual read. Thank you ALL. .
Old Aug 10, 2023 | 08:50 PM
UltraSeattle
6th Gear
Yes, Rounders... the oil pressure is in normal range when motor is cold. When it warms up, oil pressure gauge shows zero at stoplights/at idle.
Old Aug 10, 2023 | 09:53 PM
hattitude's Avatar
hattitude
Originally Posted by UltraSeattle
Oil light does not illuminate while idling or at any time when oil pressure gauge is at zero. Hasnt been hot here in Seattle; 74 for a high temp when I was riding.
To check the oil pressure, you just temporarily put a manual pressure gauge in the spot where your oil pressure sending unit is... take the readings and then reinstall the OEM oil pressure sending unit.
However with the no oil light when the pressure reads zero, and a smooth, quiet engine.... I'd just ride it... If it starts to make unusual noises, I'd investigate further..
Old Aug 10, 2023 | 10:01 PM
Rounders's Avatar
Rounders
If it reads high when cold, that makes me wonder if it could be accurate. When you say hot, how hot? Warmed up for an hour, or stuck in traffic at sturgis? Sturgis hot it can drop to zero at idle, and then go up when revved. Normal riding hot, my 88" does not go to zero.
Also need to keep in mind when reading, is I believe they changed oil pumps, guessing with 96" My 88 and 96" have different values, 88 reads higher.
If you are pushing 60 psi when cold, that makes me wonder if gauge is working. I don't know how gauges work. I just basing that off at times it reads high
Mechanic friend of mine scuff at gauges, says you will hear lifters. But that is not to say it cannot be tool.
If it reads high cold, and then goes low when hot. I would be thinking about this. It implies to me the gauge is working over a range of PSI. Again I don't know how gauges work.
Old Aug 10, 2023 | 10:03 PM
Rounders's Avatar
Rounders
Is this a change or is the bike new to you?
Personally all my bikes I also run 1/2 quart low cold engine. That first 1/2 quart goes fast, especially on 88s.
Old Aug 10, 2023 | 10:08 PM
Rounders's Avatar
Rounders
I
Details:
* Bike's oil gauge at highway speeds shows pressure just shy of straight up (about 24-26) vs pointing straight up at 32.
Thanks for any insights.
Originally Posted by ybnorml
Re-read post #1...at idle, or at a stop light, nothing about interstate !!! Damn
If I want to know how to butter my biuscuits I will ask you.
I am sorry my groupies follow me around.
Old Aug 10, 2023 | 11:55 PM
tdrglide's Avatar
tdrglide
Put a new sending unit on it. Not that hard to do. A little awkward maybe. Ive had one fail before. Showed low on gauge. It only takes 2 or 3 psi to make the light go out. Gauge itself could be off that much. Or swap in a mechanical gauge for a test. Watching a gauge read zero would bug me even if I knew it wasn't actually zero.
Old Aug 11, 2023 | 01:08 AM
Ron750's Avatar
Ron750
The oil pressure on my ‘03 Ultra was very low at warm idle. At 30k I had the SE Cam Chain Tensioner and oil pump upgrade. The pressure goes up 10-15 psi across the board after that. Engine was a humming dynamo after that.
Old Aug 11, 2023 | 08:28 AM
ybnorml's Avatar
ybnorml
When ever I want or need bad advice on anything, I know you will have a bag full....
Old Aug 11, 2023 | 04:16 PM
UltraSeattle
6th Gear
Rounders, I bought my Ultra new in 2005... the gauge showing a drop in oil pressure to zero at stoplights (after the engine is warmed up) is new. This started happening about a month ago following a four-hour day trip.
