99 Electra glide ultra classic ignition problems!
Old Aug 18, 2023 | 05:16 PM
Kmac99's Avatar
Kmac99
Stage IV
Default 99 Electra glide ultra classic ignition problems!
Hey all,
Got a 99 ultra fuel injected the other day and after replacing the fuel pump and crank sensor got it to fir up after sitting a year plus. Crank and ran several times but now when I turn the ignition on the fuel pump doesn’t prime nor does the engine light flash or come on. Turned the ignition switch on just a while ago and pump came on eng light came on then I heard the relay click off. Turned the ignition off and back no and right back to no fuel pump or eng light. Bike will crank over just never fires and I’ve learned the ignition and fuel pump are all on the same circuit just don’t know what to check for to isolate the cause of the lost power.
Old Aug 18, 2023 | 07:47 PM
svarnster's Avatar
svarnster
sounds like main relay or fuse
Old Aug 18, 2023 | 07:50 PM
Kmac99's Avatar
Kmac99
Stage IV
I’ve changed the main circuit breaker and 2 relaysall fuse’s including the 2 only for the ECM are all good. It just randomly works or doesn’t it seems. I can’t find a actual diagram for the relays.
Old Aug 19, 2023 | 09:18 AM
im's Avatar
im
You report "when I turn the ignition on the fuel pump doesn’t prime nor does the engine light flash or come on."
What else did you disconnect when servicing the bike?
Some bikes have a wire that runs on top of tank but under tank console with a push like connector that many people forget to reconnect.
Runs from fuel tank access panel towards seat.
Try to rule-out key switch and run/off switch at handlebar?
With handlebar switch on RUN
Turn key switch to ON
Do you have dash lights?
With handlebar switch OFF
Old Aug 19, 2023 | 09:31 AM
Kmac99's Avatar
Kmac99
Stage IV
All connections for the fuel pump change are good. Mine had just the 2 spade connections at the canopy and the one ground on top. Bike has cranked and ran since all maintenance was done.
With run switch on all dash lights work and bike will turn over.
With run switch turned off all dash lights work but the bike will not turn over.
Randomly with no rhyme or reason I can turn the ignition on with the run switch on and the pump will prime and eng light comes on as it’s supposed to then I can turn it off wait a few come back no prime or eng light indicating ECM is running it’s test. I know the fuel pump will only prime when the pressure requires but the lack of eng light and power to the pump and coil is what has me scared to say ECM
Any advice I appreciate GREATLY!!
Old Aug 19, 2023 | 12:37 PM
~XLer8~'s Avatar
~XLer8~
I have a 1999 Ultra Classic and one day after stopping for lunch the bike would not restart, no electrical power whatsoever when turning the ignition on. I got home by making a couple jumper wires from the battery to the fuses for ignition and ECM. When I got home I discovered a burned terminal where the ignition switch harness hooks into the main harness behind the fairing. I used a butt connector to bypass the connection and had no problems since. I wonder if yours could be something similar where it’s not a total loss of power but enough of a voltage drop that the ECM won’t wake up.
Old Aug 19, 2023 | 03:06 PM
Kmac99's Avatar
Kmac99
Stage IV
I could see that but I’m getting a good voltage to the ignition and ECM fuse. I’ve pulled both fuses and cleaned them and shot continuity and the fuses are good. It’s hard for me to believe the ECM just crapped the bed randomly I’m leaning more to a ground had a bad connection already and when it cranked last it vibrated to a worse connection possibly.
Old Aug 19, 2023 | 03:21 PM
heDONist's Avatar
heDONist
Default Recall?
My 1998 flht had an ignition switch recall. Can you look it up to see if it effected your bike also, and if it was done.
Old Aug 20, 2023 | 06:45 PM
svarnster's Avatar
svarnster
handle bar kill switch
Johnsan93
Sep 24, 2022 10:51 AM
Mapa-HD
May 28, 2021 09:29 AM
Lee79
General Topics/Tech Tips
Jan 19, 2020 02:59 PM
mikemedic3
Aug 13, 2019 06:45 AM
blkfxstc
Oct 1, 2008 07:49 PM
