Clutch Churpping
Old Sep 13, 2023 | 06:49 PM
103Ridetolive's Avatar
103Ridetolive
Stage IV
Default Clutch Churpping
Hi All,
I ride a 2013 Road Glide Ultra
This year I installed Barrnet’s extra clutch ,it was great for about 500km and then it started.
When I would would take off from a dead stop my clutch would Churp. Very Annoying, It would not slip it would just churp.
Any feedback would be much appreciated
Thanks, Dean
Old Sep 13, 2023 | 07:15 PM
Jackie Paper's Avatar
Jackie Paper
Can't help you with your question but this will keep you on top
PS. Welcome, hope you enjoy your ride here.
And as a suggestion, make your next new post over in the new member welcome area to say hello.
Old Sep 14, 2023 | 01:03 AM
Taxgod4u's Avatar
Taxgod4u
I have tha same issue, board responses said it was normal and to try different primary fluids. I just ignore it when it does chirp as it is only once per ride.
Old Sep 14, 2023 | 02:01 AM
Ghost_13's Avatar
Ghost_13
Barnett's are very grippy and require a lighter and more instantons touch (only way I can describe it)
You're fine
Ghost
Old Sep 14, 2023 | 07:27 AM
Hecklerboy's Avatar
Hecklerboy
Check your drive belt.
Had a lose drive belt on my Sportster and it made a chirping sound when I would take off.
Old Sep 14, 2023 | 02:15 PM
dynoking's Avatar
dynoking
How about contacting Barrnet?
Old Sep 14, 2023 | 02:30 PM
mike131's Avatar
mike131
You can try running ATF in it, I run ATF type F in my primary
Old Sep 14, 2023 | 02:43 PM
springers4ever's Avatar
springers4ever
Cool Stock plates ...
Originally Posted by 103Ridetolive
Hi All,
Thanks, Dean
Why did/would you change from stock plates to aftermarket ...are you making any big H/P to justify the change !!??
We have found that the extra plate works well in high power bikes ...but the stock clutch needs the small bevel plates (that you took out) in order to shift smoother and find neutral better . Because it helps spread the clutch plates better being deeper in the pack...which is why we think you are hearing the churpping when trying to leave off slowly ...the clutch pack is not spreading apart enough ...IMO ...
the extra plate will work good for while till the oil is spun off the plates and they get dry then really start to grab...making the churpping noise and you will start to feel it shutter a little too ...
it wants to grad when you want it to slip a little when leaving off ...
replace with stock ...check the adjustment again ...
good luck ...
Old Sep 23, 2023 | 08:59 AM
103Ridetolive
Stage IV
Default clutch
good luck ...
Thanks All for the Comments
mostly Ride two up and pull a leisure light tent, trailer that’s why I went to the extra clutch. Also run Red line Racing ATF (F)
sh4325
2014-2024 Touring Models
14
Jul 1, 2022 12:13 AM
touchdown
Jun 1, 2021 05:39 AM
paid4c4
40
Apr 18, 2021 05:07 PM
turtle2
May 30, 2010 10:31 AM
baron3547
Oct 5, 2006 12:35 AM
