Heated Grip Replacement
I swapped out my factory heated grips last fall for a set of the HD Big Kahuna grips on my Ultra Limited. Where's the easy plug and play part?
I was in no hurry, but it took several hours to wrap up. It's a little bit involved.
There is no easy plug and play. It's a fairly involved process that takes a few hours.
If you're replacing heated grips, unplug them inside the fairing (under the gauge cluster on road glides) and tape a fish wire to one of the harnesses (power or interconnect) before you pull the old clutch side grips off. Don't tape it to both, because if they went around another harness inside the bars (switch pack harness or something) on opposite sides of each other when they were installed, you're gonna get caught up on that.
Also, If buying HD grips, other than Kahunas, be sure to check before you buy, the install instructions... a lot of them having a fuse block/link on the power wires that ain't gonna fit thru the bars and have to be run externally. I'll be doing another set to my new bike this winter... just waiting to see if HD is going to make push button ones available for the touring line, like that is on the new CVO's... if not it'll be another set of Kahunas lol also, don't forget to take the grey bushing out of the new clutch side grip BEFORE you pull the wires thru the bars...
It is really simple to do, but because you're pulling wires, screwing with the clam shells, trying to find connectors tucked away... it can easily get to be a pain in the ***. Don't rush and think before you do the different things... like pulling stupid hard on the wires instead of working or lubing them, pinching wires in the clam shells, or getting them to fit back together right.... or my favorite, getting that damn plug back in on the end of the throttle's grip.
Plenty of space? LOL.....no.
My post that you quoted I described as simply as I could what was involved. You get new wiring and connectors for both grips. Why would you leave old wiring when you have new?
That's not how I do things.
