Looking for a code. 32684-04
Old Oct 22, 2023 | 06:30 PM
AllHaugFxr's Avatar
AllHaugFxr
Stage III
Default Looking for a code. 32684-04
Hey guys, I have a 2005 Carbureted Roadking here that has no spark. The code I'm receiving from the gauge is P0371. Then it gives me a part number that as far as I can tell doesn't exist. 32684-04.
P0371 seems to be related to the cps, but I have three new cps sensors in stock and nothing changes with any swap. I'm scratching my head...
Any help would be appreciated. I'd like to get it out of the shop.
Old Oct 22, 2023 | 06:54 PM
CoolBreeze3646's Avatar
CoolBreeze3646
P0371 CKP sensor wrong number of pulses
I think 32684-04 is the ICM Part Number, should be printed on the ICM (Ignition Control Module) or
through System ID using Digital Technician.
Old Oct 22, 2023 | 07:03 PM
AllHaugFxr's Avatar
AllHaugFxr
Stage III
I thought that too. I looked at the icm and the number on it is 32478-04B. My understanding is that this is the updated icm. I have another with the same number however ending in A and changing it doesn't make any difference.
Old Oct 23, 2023 | 02:57 PM
hattitude's Avatar
hattitude
Anytime I am chasing an electrical problem, I start with the battery. A weak/bad battery can cause all sorts of issues. Don't just measure voltage, but also do a load test.
Once I verify a good, stable 12v source (battery), I clear the code(s) and then see if they reappear. If they reappear, I investigate the code.
If you get the P0371 code to reappear, then I would suspect the CPS is the cause... I would check it out completely, before buying a new ICM..
If you know the new CPS you have tried are good, then look closely at the CPS connector. Make sure there are no dirty, corroded, or bent pins that could affect the signal. I'd also check the wire all the way back to the ICM for possible breaks or bare spots. Once back to the ICM, check that connector and make sure there are no dirty, corroded, or bent pins that could affect the signal...
Also, if it were me, I would test the pins on the ICM, per the electrical diagnostic manual before buying a new one... If you swapped out a known good ICM and it doesn't work, I would be even more suspect of the connectors & wiring between the CPS & ICM....
Good luck with your diagnosis and report back what you find...
Old Oct 27, 2023 | 01:37 PM
AllHaugFxr's Avatar
AllHaugFxr
Stage III
Thanks Hatitude. I'll let you know when I can get back to it.
masterofyard
Jun 3, 2022 05:13 AM
Alex Hamilton
Apr 24, 2015 06:49 PM
sincityharley
Dec 23, 2010 09:28 PM
gmeigel
Aug 24, 2010 02:38 PM
Sledge
Jan 19, 2010 03:12 PM
