Add-On Gauges
Old Nov 19, 2005 | 03:25 PM
Cohiba_Joe's Avatar
Cohiba_Joe
Default Add-On Gauges
I just received the aftermarket fairing for my '05 RK Classic. I've already setup the stereo / speakers and will also be adding some gauges. What I had in mind was a tachometer, oil pressure and oil temp. Are there any other suggestions as to what I should add? I already have a fuel gauge / voltmeter combo and the stereo has a clock.
I'm also looking for input in regards to the HD 2" Tach, 1.5" gauges or any aftermarket gauges that would work. Not sure if the HD gauges would be too small. I would of course also need the appropriate sensors. Due to the fairing being a quick detach I would like to stay with electrical gauges as opposed to mechanical since it would be much easier to make a single connector for everything.
Thanks for the help,
Brian
Old Nov 19, 2005 | 03:52 PM
Harley Rulz's Avatar
Harley Rulz
Default RE: Add-On Gauges
It sounds like You have it covered to me Joe.A buddy of mine put a compass in the spot where his air temp guage was and it's alright but if you have a sense of direction,I would pass on it.Let us see some pics when you git-r-done.
Old Nov 19, 2005 | 11:44 PM
CHEYENNE's Avatar
CHEYENNE
Go with all Dakota Digital Guages
Old Nov 20, 2005 | 12:01 PM
luvmyflhtcui's Avatar
luvmyflhtcui
Keep the Road king like it is and buy a matching Street Glide or Ultra Classic.
Sorry....I had to.
Digital is the way to go!
Good luck. Let's see some pic's when you get it all together.
[IMG]local://upfiles/494/BFEC642CAB054498963CFD783BFFB2F9.jpg[/IMG]
Old Nov 20, 2005 | 12:11 PM
harleygunnow's Avatar
harleygunnow
Brian
Which radio did you end up with?
Old Nov 20, 2005 | 04:30 PM
Cohiba_Joe's Avatar
Cohiba_Joe
Looks like the Dakota Digital will be getting a fair shot in the pricing wars. Just not sure if I want change the look bewteen the stock speedo (being analog) and the new gauges. And I can probably say that doing it this way will be a tad bit cheaper than buying an additional EG. However that is a nice thought except I have a hard enough time deciding what I'm going to eat for lunch let alone trying to decide what bike to ride - LOL
I ended up using the Sony CDX-R5515 with a pair of Infinity marine speakers 602M. Sounds great and no problems hearing the tunes (at least in the test environment - in the garage, fairing on saw horses, stereo playing MP3 disc, bike running with the exhaust reverberating off the walls).
Brian
Old Nov 21, 2005 | 10:56 AM
RoadKing52's Avatar
RoadKing52
Joe, Cam you tell me where you got your fairing, I've got an 03 FLHRCI and have been thinking about adding one but haven't liked the ones I've seen so far.
Thanks Carl
wulffe
Aug 28, 2011 08:32 PM
jcbpa
Dec 16, 2008 08:54 PM
mchildree
Aug 16, 2008 08:22 PM
iclick
Feb 28, 2007 03:18 PM
Cohiba_Joe
May 4, 2006 10:53 AM
