help please!!!!!
Old Aug 26, 2007 | 09:16 PM
thall's Avatar
thall
Default RE: help please!!!!!
I know the dealer would say a remap
Old Aug 26, 2007 | 09:19 PM
Beancount1's Avatar
Beancount1
I had screaming eagle slip ons put on without remap or air cleaner. Runs great. Slightly more power and great rumble, but not too loud.
Old Aug 26, 2007 | 11:32 PM
quint's Avatar
quint
Bagger
You definitely should get a remap. Here's why...
The Harleys from the factory are very LEAN. They do that in order to pass the EPA emission standards. It's a somewhat artificial standard, because it mostly measures drive-by emissions at part throttle settings (typically 20 - 40% throttle). However, when you add a less restrictive slip-on, you increase the airflow. Net result? It's even leaner.
If you get an EFIremap, you will get a better running, cooler running, longer lasting bike that is far more responsive, is less prone to pre-detonation (pinging) and doesn't pop or backfire. If you go further and get a remap through either the Screaming Eagle Race Tuner (SERT) or Power Commander III (or many of the others), you will probably pick up 8-15 lb ft of torque and maybe 5 - 10 Hp, plus better economy. There are many excellent articles on this subject, including our very own Terry1955 here...
https://www.hdforums.com/m_181817/tm.htm
or Joe Minton at American Rider magazine, who writes about it on a very regular basis, but you could start here...
http://www.americanrider.com/output.cfm?ID=1022023
Believe me, it's worth getting it done right, otherwise you're only getting 80% of the bike's potential.
Old Aug 27, 2007 | 12:18 AM
grooveman's Avatar
grooveman
Bagger before I installed my SE slip ons I started a thread on this exact same topic. I believe they ALL said with that exhaust only, no re- map was needed. I also called my dealer and asked them the same question. Same response, no remap needed..
Now if you increase the airflow by adding the stage one air thats a different story, you are increeasing airflow and will need to richen it up thus you will need some type of fuel management system whether it be a SERT, PCIII or whatever.
Old Aug 27, 2007 | 01:56 AM
Bobberino's Avatar
Bobberino
I have a thunderheader on my 07 SG and it does tend to run hot. As soon as I have enuff cans to recycle Im gettin the cleaner and PCIII.
Old Aug 27, 2007 | 11:11 AM
carlosgtn's Avatar
carlosgtn
I have this question in another thread. I took the Vance and hynes slip ons from my old 98 FLHTCI and put them on my 06 FLHTCI. I noticed a lot more back firing on decel and the bike running hotter. One dealer said I need to tune the bikeor I will burn the valves and in time ruin the engine price around $700( not the dealer I use ) andthe dealer I get my services done at, said I should not have to doanything because the 06 models have the o2 sensors in the headers. I would like a few opinions from you guys before I go $$$$ crazy !
Old Aug 27, 2007 | 11:20 AM
Hogtoad's Avatar
Hogtoad
I have an 07 Ultra, put se mufflers on, no problems. I will be putting se air filter set up on when I get first check up, then they can re-map the thing.
Old Aug 27, 2007 | 04:06 PM
07bagger's Avatar
07bagger
so what am i looking at for getting muffs,programmer and cleaner put on my bike and out the door?thanks
Old Aug 27, 2007 | 04:23 PM
Blues Guy's Avatar
Blues Guy
I just had Stage I, a SERT and true duals installed by the dealer - total cost $1700. So if you're just doing slip-ons, I'd cut $400 off of the pipes and $50-75 off labor, depending on what you buy.
Bonedoctor21
Jul 10, 2011 11:35 AM
Dalejo
Oct 10, 2008 09:06 AM
snooper0069
Jul 23, 2007 01:11 AM
traveler
Exhaust System Topics
Jul 27, 2005 04:56 AM
