Starter circuit wiring help needed
Old Nov 14, 2023 | 11:36 AM
GOGOBECK's Avatar
GOGOBECK
Default Starter circuit wiring help needed
2001 Road King Classic
She starts if I bypass the starter relay with a jumper.
(yes I know and I have a solenoid push button cover on the way)
I’ve swapped the starter relay with the brake light switch and verified it’s working.
The Run/Off switch is working (fuel pump tells me so)
I metered the push button start switch at the Deutsch connector under the nacelle and it shorts between the Black/red and grey wire when pushed.
I have continuity on the black/red from the Deutsch connector to the relay and from the grey at the connector to one side of the 15amp ignition fuse.
This is where I’m lost… where does the other side of the 15 amp ignition fuse show up? The grey of the ignition switch plug ?
Any suggestions from here?
Old Nov 14, 2023 | 12:20 PM
GalvTexGuy's Avatar
GalvTexGuy
Old Nov 14, 2023 | 12:53 PM
Ultra103's Avatar
Ultra103
Originally Posted by GalvTexGuy
~didn't say "get a service manual"~
Good man.
Old Nov 14, 2023 | 01:18 PM
GOGOBECK's Avatar
GOGOBECK
Ha ha, I’ve got a service manual!
I did check the ignition switch, I have 12.6v on all 3 terminals when the switch is on.
What does the turn signal/security module have to do with the starter circuit ?
It’s where the other side of the ignition fuse goes!
Old Nov 14, 2023 | 01:28 PM
GOGOBECK's Avatar
GOGOBECK
Pin 2 at the ts/s module connector (grey from ignition fuse) has 12.4v when ignition switch is turned on… also when ignition switch is turned on the run/stop switch doesn’t affect the 12v
I’m at a loss what to check next
Old Nov 14, 2023 | 03:35 PM
Vernal's Avatar
Vernal
Check the TN/GN it should provide ground through the TSM/TSSM for the start relay.
Old Nov 14, 2023 | 03:48 PM
GOGOBECK's Avatar
GOGOBECK
I get 12 ohms resistance with the ignition switch off, 30 ohms w/ switch on. No change when I press the start switch
Old Nov 14, 2023 | 04:12 PM
Vernal's Avatar
Vernal
With everything connected can you find a way to ground the TN/GN wire and see if the starter button works?
Old Nov 14, 2023 | 04:43 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Remove the starter relay, read voltage at the connector where pin 86 goes when the start button is pressed (Black/Red wire).
What is the voltage?
This is the diagram for the starting circuit:
Starting Circuit
Old Nov 14, 2023 | 05:08 PM
GOGOBECK's Avatar
GOGOBECK
I was able to get a ground to the TN/GN with everything connected… nothing when pressing the start button
[QUOTE=Dan89FLSTC;21453952]Remove the starter relay, read voltage at the connector where pin 86 goes when the start button is pressed (Black/Red wire).
Starting Circuit[/QUOTE
I get no voltage on pin 86
