Electric Idiot
Old Aug 26, 2007 | 09:36 PM
pipermcnut's Avatar
pipermcnut
Default Electric Idiot
(no one answered this when I posted in the tech-forum)
How many connectors can be piled up on the battery posts?
So far I have my battery tender hookup; my led lights; my new DCC fairing/stereo connection; plus the battery cables-- its getting crowded on those little posts!
Old Aug 26, 2007 | 09:39 PM
SIM's Avatar
SIM
Default RE: Electric Idiot
You can pile up as many as you want as long as you do not exceed the ouput max amperage of the charging system.
Old Aug 26, 2007 | 09:44 PM
TexasRedneck's Avatar
TexasRedneck
Actually, you'd do well to run over to a small power distribution panel - check with the folks at Electrical Connection - Lewis Preston likely can come up with what you'd need.
Old Aug 26, 2007 | 09:57 PM
SoCal_Pappy's Avatar
SoCal_Pappy
TexasRedneck is 100% correct.... If you run a power block it limits the direct connections to the battery and less chance of corrosion build up or a weak connection
Old Aug 26, 2007 | 10:21 PM
TexasRedneck
Yeah...wahl, let's jest say that ah'm hopin' ta avoid the electronics ah've added ta past bikes....ah've upwards of 17 dedicated-circuit relays on several of 'em!
Old Aug 26, 2007 | 10:26 PM
SIM's Avatar
SIM
I guess my orginial answer was more centered on the few connections he has on the battery at present. Installed car audio for a living in the 90's and i know you remember the earth shaking bass that was in every car around then. In higher amperage applications we used power dist. blocks, but for average installs the simple connections to the battery were fine. 12v is 12v.
Old Aug 26, 2007 | 10:43 PM
beemer737's Avatar
beemer737
One, leads to a battery tender. All other power draws should come off the power or grounding block sitting next too and below the battery.
The more stuff you pile ontop the battery terminals, the more chances your going to loose ground or hot through higher impedance, corrosion, etc...
Old Aug 26, 2007 | 10:44 PM
TexasRedneck
True...but when yer tryin' ta git in ta service the battery and/or clean the terminal(s), all those leads can get in the way in a hurry - not to mention the hassle of tryin' to tuck all the in-line fuses out of the way (anyone that doesn't install fuses on a power lead deserves the electrical fire they'll eventually get). A distribution block just makes for a MUCH cleaner install, IMO.
Old Aug 26, 2007 | 11:50 PM
goodbirds's Avatar
goodbirds
just keep the cables first on the posts to keep the amps moving while starting.
Old Aug 27, 2007 | 07:47 AM
SIM's Avatar
SIM
ORIGINAL: TexasRedneck
How very true.
pt4u2nv
Jan 20, 2017 08:36 AM
Mchad
Nov 23, 2015 06:02 PM
fatboy1729
Electrical/Lighting/Alarm
Nov 17, 2014 03:15 PM
dinolo24
Nov 14, 2014 09:53 AM
pipermcnut
Aug 17, 2007 12:57 AM
