Help with throtle by wire
Old Dec 13, 2023 | 03:18 PM
pkdels's Avatar
pkdels
Default Help with throtle by wire
installed 12 inch ape hangers on a 2011 flhtcu , unhooked all connectors found 1 connector not connected ir is black with 2 wires,it is attached to the throtle there are 2 connectors 1 is green with 6 wires the other is black with 2 wires, i can not figure out where the black connector plugs in .anyone know where this plugs in,s bike starts , able to rev the motor ,have not driven it
Old Dec 13, 2023 | 03:29 PM
cj24's Avatar
cj24
It helps to pay high attention to detail when taking things apart ... and take pictures. Really helps with reassembly. Even with that it can be a pain lol. I recently did bars on my 21 King. If I remember correctly there were plugs for heated grips - if you do not have heated grips that may explain what you are seeing. Not knowledgeable at all on that year, I'm sure someone who knows will respond soon.
Old Dec 13, 2023 | 03:30 PM
GalvTexGuy's Avatar
GalvTexGuy
What color are the two wires?
As mentioned above, they may be for heated grips.
Old Dec 13, 2023 | 04:09 PM
MyFavRk's Avatar
MyFavRk
Yup , like said above , that plug is for heated grips , guessing you don't have any .
I've done a dozen or more bar changes , the green connector , once unattached can cause issues . Before you button everything up , power up your bike , check for codes and make sure everything is running / working properly . Also , it would be a good idea to use some shrink wrap or electrical tape over that connector , just as a precaution if you decide to keep it .
I have always cut and soldered those wires , removing the green connector all together , never had an issue .
Old Dec 13, 2023 | 04:25 PM
pkdels's Avatar
pkdels
thanks for the replies , i t kinda makes sens now ,searched fo a hour for other end
AlphaDogg
Mar 31, 2021 11:57 PM
cookiemech
Milwaukee Eight (M8)
20
Oct 16, 2020 06:07 PM
Teddyboy
Mar 4, 2020 07:48 PM
Msquad
Oct 23, 2017 07:55 AM
decencyxdefied
Feb 18, 2014 12:25 PM
