Can you remove packing in mufflers without modifying tune?
Computer control doesn't apply to the open loop portions of the tune map. If you wait for an engine light from the closed loop portions of the map before a retune, you are most certainly way out of spec on the open loop portions of the tune map.
The closed loop portion (adjusted by the ECM w/ O2 sensor feedback) is mostly cruising areas of the map, and low load, lower rpm portions of the map.
The open loop portions of the map, operate outside the accuracy range of the narrow band OEM O2 sensors. Therefore the open loop portions of the map are in the high rpm, high load areas of the map. These critical open loop portions are controlled by algorithms based on the OEM configuration of the engine, and are not adjusted by the computer & O2 sensor feedback.
If you increase airflow, only the closed loop areas are computer adjusted, and the open loop are going to be leaner. Depending on the amount of change, and the riding style of the bike's operator, some open loop areas could get very lean....
If the bike is tuned for OEM, Stage I, Stage II, Stage III, etc, etc.... The tune not only changes the range of the closed loop operation, but also adjusts the AFR of the algorithms in the open loop sections.
IMHO, if you deviate a small amount from the state of tune, while you may not have the "optimum" tune for that bike, it should not harm anything.
But the farther from an OEM (or other stage) tune you stray, you can tax the closed loop adjusted portion and you definitely are pushing the open loop, non-adjusted portion. The more you stray, the more important your riding style affects the safety of the tune.
A bike tuned for racing, can still develop tune related issues in a Race type environment. We all know that a good street tune can be "tested" by a "ride it like you stole it" operator. Imagine how much that same tune would be "tested", if it started out already behind (lean) in the open loop, non-adjusted portions of the tune...?
FWIW....
On my EFI bikes, I always adjust for a change in airflow. It may just be a basic auto tune, dialing in the VE tables on a simple change. It will surely be a new map, and/or Dyno Tune for larger mods (cams, displacement, headwork, etc).
It seems to me that the changes from simply removing the packing wouldn't be overly severe. If anything, it seems it should worsen flow. When new and tightly wrapped, the scoops in the main tube end right in the packing, so virtually no exhaust gasses go into the outer chamber, just sound waves. With the packing removed (or blown out), exhaust gasses now could go through those scoops and out into the outer chamber. This would start restricting flow, much like the water valve from Nikola Tesla.
Reading things on packing mufflers from several manufacturers seems to bear this out. All reporting power loss from an unpacked muffler. Not huge reductions, but real. Small enough to be dubious of detection by the classic butt dyno.
I agree with Hattitude that while you're likely to get away with it, you also could put yourself far enough outside optimal operation that it causes minor problems like a stumble or intermittent backfire or such. Would you "need" to fix it with a retune? Probably not. Using my old TC88, I suspect it was tuned, and to the straight pipes it had when I bought it. When I put stock pipes on it it ran just fine, save for an intermittent "sneeze" through the intake when running low rpms and working the throttle quite a bit (fire road riding and the like). It didn't do that with the straight pipes. Though it's a worthy question if I ever could have detected it with those loud pipes. It was never enough of a problem that I bothered to address it. I just lived with it, knowing it would sneeze sometimes.
The reality about changing mufflers and air cleaners is that they don't make a meaningful difference in those things. If they did, the computer would be unable to compensate for altitude, atmospheric pressure, temperature, and even a dirty air filter, all of which make a much bigger difference than what (or if) you have a muffler installed.
People think just because they hear more noise that they've done something that makes a difference but if you actually look at the fuel trims, it's noise at best. Because unlike a carb, the EFI adds fuel based on measuring the combustion process, not the amount of air passing through the throttle body.
The O2 sensors are either heated, or unheated and warmed up by exhaust gases. They do need to warm up to operate properly...
OEM narrow band O2 sensors, fully warmed up, still only accurately cover an AFR range of 14.3:1 to 15.2:1. That's why the warm up tables in a tune, only affect portions of a tune map covered by O2 sensor feedback. When the bike is up to operational temperature, there are still areas of the map that require an AFR richer than 14.3:1 (high load, high RPM), and do not have closed loop monitoring or adjustment. If a tune map cell calls for an AFR richer than 14.3 (or maybe 14.4, I forget) the tune automatically switches from closed loop to open loop.
On an OEM ECM tune, the closed loop portion never covers all areas of the tune map. It only covers that narrow band O2 sensor range which is just a portion of the tune map (mostly cruise). On a tune map for a highly modified engine, that range covers even a smaller portion of the tune map.
You can run a DynoJet Target tune, Thundermax ECM, or a couple other aftermarket modules that will change to wide band O2 sensors, and once warmed up, the entire tune map is in closed loop, and has O2 sensor feedback and adjustment.
There are some "issues" with running wide band O2 sensors for the entire tune map, the biggest being that wide band O2 sensors respond slower than narrow band sensors. In fact a lot of racers and other people with really high performance engines would rather run complete open loop tunes due limitations with O2 sensor feedback.
All this was to say that on a fully warmed up OEM ECM tune/engine, there are still open loop portions in the areas where AFR can be critical if not properly adjusted. It doesn't take someone to "beat" on their bikes to be in these map areas. Sometimes just normal riding will put you into these areas and push your bike with a lean tune condition, ie: Two up touring with a bunch of luggage, going uphill at altitude.
