Any one having problems with HD brand auto primary adjuster ?
Old Aug 27, 2007 | 09:48 PM
sportyrider1's Avatar
sportyrider1
Default Any one having problems with HD brand auto primary adjuster ?
OK Guys I am going to add auto primary chain adjuster to my 03 RK. after looking at the HD brand and how it works I need to knowif there is a issue with putting it on with my old chain with its tight and loose spots 0r would I be better off using a different brand / style
Old Aug 27, 2007 | 09:57 PM
choochoo's Avatar
choochoo
Default RE: Any one having problems with HD brand auto primary adjuster ?
my 06 egc had about 15k when I installed it.
Seems fine except I may have gotten it a little snug as I get some audible hum from chain rubbing across the nylon shoe.
But if you're concerned put a new chain on at same time.
When installing make sure to rock the engine crankshaft back and forth a couple times with a wrench on the compensator to take up the slack.
Let the adjuster do it automatically, don't pry it or force it tighter.
And you should be fine.
Old Aug 27, 2007 | 10:00 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Put one on the '01 RKC workin' good...
imboden
Aug 23, 2014 08:21 PM
martin1
General Topics/Tech Tips
May 18, 2014 03:19 PM
kpolak
Feb 28, 2010 06:49 PM
MidnitEvil
May 10, 2009 11:30 PM
stevet82002
Apr 12, 2008 09:49 AM
