EZ Up Center Stand
Old Mar 12, 2024 | 12:56 PM
Bproctor's Avatar
Bproctor
Default EZ Up Center Stand
I'm thinking about ordering one of these but wanted to see if anyone else used one on a Street Glide ST. Also do they get in the way for any maintenance? Thanks all.
Old Mar 12, 2024 | 01:01 PM
runnhrd's Avatar
runnhrd
I have used mine on my 2011 Road Glide and works fine. Only issue is when cornering or going over speed bumps you will drag sooner than you expect.
Old Mar 12, 2024 | 01:32 PM
Bproctor's Avatar
Bproctor
Thanks. The ST has a 1" lift so hopefully that will offset that problem a little. I went ahead and bit the bullet.
Old Mar 12, 2024 | 01:34 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I had one for years under my 04 RK. Worked like a treat, didn't get in the way for any of the regular maintenance.
I was surprised that I was never grinding it on anything. Not disagreeing with runnhrd's experience, just they weren't mine.
Old Mar 12, 2024 | 08:08 PM
jd05flhtci's Avatar
jd05flhtci
I had one on a 2016 SG and now on my 2018 RGS and never had an issue with dragging or maintenance.
Old Mar 12, 2024 | 08:19 PM
TXNT's Avatar
TXNT
I have one on my 2021 Street Glide. I love it. I only drug mine once on a speedbump but I was 2 up with bags loaded and a bag on the luggage rack. It also saves room in the garage because it sits vertical. I have a wheeldock for my other touring bike. The two combined save room in my garage.
Old Mar 12, 2024 | 09:24 PM
ramu3527's Avatar
ramu3527
How about using a jack style bike lift? Is there an issue with that?
Old Mar 12, 2024 | 09:47 PM
Taxgod4u's Avatar
Taxgod4u
That'll drag sooner than a center stand
Old Mar 12, 2024 | 10:13 PM
hamah's Avatar
hamah
Worst "upgrade" I ever made. Put the bike down on it's side when I thought I'd properly extended the stand from a seated position (ok...my fault). Almost killed me when one of the pivot bolts worked it's way free and I caught the drooping end of the stand on a speed bump. Nearly cantilevered the bike right up and over the front wheel! Scary **** right there. Realized there was nothing wrong with the jiffy stand and I was never going to use the EZ-Up for maintenance purposes (I have a lift for that). The very nice people at Wheeldock had no issue with me returning the stand for a full refund.
P.S. I'd also read all the great reviews and watched the YouTube videos so I figured it was money well spent...it wasn't
Old Mar 13, 2024 | 08:18 AM
Bullwinkle58's Avatar
Bullwinkle58
I've been thinking about getting one also. I keep imagining having a flat rear tire & having to roll the bike a few inches at a time by myself trying to find a puncture. It would also make it way easier to check tire pressure. I have Fobo tire pressure monitors, but with a center stand I'd get rid of them. The app drains my phone battery when I'm logged in.
