Gadgets I need for wireless Apple Carplay ....
Old May 23, 2024 | 04:18 PM
  #31
Joe741's Avatar
Joe741
Default Disconnect WHIM for Jumper?
Originally Posted by kojak
Mine was on a cvo bike with the whim installed and the GTS radio. Jumper doesnt work on that setup, you need a headset connected to enable Car Play and then you can plug in the phone to the usb in the cubby for it to work. Your setup might be different.
I have the same setup: CVO with WHIM installed. I NEVER use the wireless headphones, and prefer to listen to music on the speakers. I have way more value for Apple Car Play than the WHIM. I was thinking of disconnecting the WHIM where the jumper would connect and installing the jumper. Just wondering if anyone has ever tried that and how did it work?? Thanks!
Old May 23, 2024 | 07:01 PM
  #32
pyuchem's Avatar
pyuchem
I do not have WHIM but just installed the Jumper and it works flawlessly.
I'm enjoying Carplay on this old bike.
Old May 23, 2024 | 07:36 PM
  #33
702's Avatar
702
Have you hucked that wireless dongle into Lake Roosevelt yet? 🤣
Old May 23, 2024 | 11:20 PM
  #34
pyuchem's Avatar
pyuchem
lol not yet. It’s been a month and that Autosky has been flawless for me. Touchwood…..At least in my case it connects right away, even before I fire up my bike.
I’m keeping my finger crossed, after all it’s electronics. Anything can happen. I’ll keep updating on how it works.
Old May 24, 2024 | 04:29 AM
  #35
kojak's Avatar
kojak
Joe, the best solution I’ve found for cvo bikes is to connect the headset module and keep it in the tour pack while riding. I just plug my iPhone into the usb in the cubby and CarPlay works great.
Old May 24, 2024 | 06:50 AM
  #36
mstrobes's Avatar
mstrobes
I have the same setup: CVO with WHIM installed. Took bike to a Indy shop and had it flashed to turn off the microphone in the WHIM. Either plugging the phone in or Autosky Car play has been flawless for me.
Old May 24, 2024 | 07:56 AM
  #37
kojak's Avatar
kojak
I think you could do that with 2020 or earlier cvo’s. I don’t know if it’s possible with 21/22/23. The 23.5 and up have an entirely different operating system for their radios.
Old May 24, 2024 | 08:33 AM
  #38
Ssitruc's Avatar
Ssitruc
I have a 23 RGL, and I still do the old "software hack" to it, that is disabling "CarPlay Mic Type", the choices are wired/wireless/disable in my software (I use Diag4Bike). But just for clarification, that does not "disable the mic", it just disables the requirement of having to have a mic to get CarPlay to be available. It makes it to where I can use a headset if I want to and the mic still works fine, and then if I don't want to use a headset I don't have to and CarPlay is still available. Any local Indy, or whoever, with TechnoResearch or Diag4Bike can still access the setting (in TechnoResearch's software the setting is not as obvious, but it does it too).
Old May 24, 2024 | 06:59 PM
  #39
kojak's Avatar
kojak
I had a 22 RGL, its a lot simpler with bikes without WHIM, I just plugged in an adapter on that bike where the wired headset port was and life was good!
Old May 25, 2024 | 08:31 AM
  #40
Ssitruc's Avatar
Ssitruc
I was just letting you know that the software hack still worked on the GTS's thru the 2023 models. If I didn't have Diag4Bike the headset plug "hack" is what I would use too. Because of that software (Diag4Bike), it is just one setting and you don't have to do anything else and then you can use a headset (mic) or not... only downside, besides having to pay to get it changed in the first place, is if a dealer hooks up to your bike with DigitalTech they could inadvertently screw that setting up for you (it's not automatic, depends on what they are doing) and a person would have to have it changed back. It has happened to me a couple times, once when we replaced the BCM to add TPMS to my 16 RGU, and another time on the same bike when we were trouble shooting a lighting issue and was in and out of several screens on Digital Tech, and I knew it was probably going to happen. But with the software it only took a few minutes to switch it back when I got home.
If I didn't have the ability to change it for myself, I'd use one like this, for wired systems with a headset jack
https://logsdonaudio.com/cables/harl...dset-connector
