Potential oil leak spot
Old Apr 22, 2024 | 01:48 PM
Sevenznuf's Avatar
Sevenznuf
Default Potential oil leak spot
Hey guys new here, I have a 2001 road kin classic, 88 ci, have a small oil drip, looks kinda like coming from these wires. In this picture I’ve already cleaned up around the wires but is this a potential spot to leak?if so what’s the fix?
Old Apr 22, 2024 | 03:23 PM
MTBIG G's Avatar
MTBIG G
Those are the stator wires and can definitely leak. On my 99 I tried silicon a few times, which worked for short periods but never really lasted. Only fix was to dig in and replace the grommet.
Old Apr 22, 2024 | 03:30 PM
memphisharley's Avatar
memphisharley
clean the area real good and use some permatex flowable silicone.
Old Apr 22, 2024 | 04:50 PM
roussfam's Avatar
roussfam
I gave it a spray with brake clean and used a toothbrush to get all around the groove in the grommet, Then I ran a little bit of black RTV gasket maker around it under the lip
That was a couple years ago been good so far
Old Apr 22, 2024 | 05:11 PM
Rounders's Avatar
Rounders
stators are a common leak point. You cannot buy the grommet. As said you can try RTV. Another option is just spray it down with brake clean periodically,
Some day when you have the primary off you could change it, based on age if you wan to. Thats is what I did with the 2 I had that leaked.
Old Apr 22, 2024 | 05:40 PM
YZR's Avatar
YZR
I second brake cleaner and RTV.
Old Apr 22, 2024 | 06:35 PM
Sevenznuf's Avatar
Sevenznuf
Thanks for the input, I got some flowable silicone and used that, I will see how that works! If that doesn’t work, how involved is it to change the grommet? Thanks for the input!
Old Apr 22, 2024 | 06:47 PM
07UltraGuy's Avatar
07UltraGuy
You'll need to remove the outer primary cover, along with the compensator, primary chain, and clutch basket to even get close to it.
Old Apr 22, 2024 | 07:24 PM
Rounders's Avatar
Rounders
It is not changeable. You need buy a new stator. Which is why I said it might not be worth it. Wasn;t for me for a few years when I had primary off for something else.
Old Apr 22, 2024 | 07:26 PM
Rounders's Avatar
Rounders
Unless you grind inner primary you will need to remove inner primary.I debate if at that point it is just as easy to pull inner primary once comp/clutch out.
