Unhappy Biker!
Old Aug 29, 2007 | 08:41 PM
John TN's Avatar
John TN
Default RE: Unhappy Biker!
ORIGINAL: tinknocker_02
Check the JB weld that comes out when you turn the star wheel on the left handgrip.
Excellant suggestion,,, you must work at a stealer???
Old Aug 29, 2007 | 08:43 PM
RED E GLIDE's Avatar
RED E GLIDE
I have a 05 EGC and 70 is about 3000 rpm. I have 13 k miles
on mine and I had a vibration that got progressively worse over
time. My selling dealer hardly fixed any complaints I ever had
so I took my bike to the next closest dealer. They not only
cured my major drivabilty problems by replacing the valve
stem seals, but they also replaced my front motor mount
for the vibration issue. The mount seemed as if it took a
month to break in and loosen up but it seem good as new.
Is your vibration coming from the power train or chassis.
The way to find out is ride at the vibration speed and pull in
the clutch and let the engine idle. If it goes away then it is
coming from the powertrain or maybe the motor mounts.
If it stays it is in the chassis or wheels.
Hope this helps.
Old Aug 29, 2007 | 08:46 PM
newtsqueensy's Avatar
newtsqueensy
As stupid as it seems, I have not done that! The dealer might have? Don't know. Will sure try that next ride. Thx!
Old Aug 29, 2007 | 08:48 PM
newtsqueensy
You can feel it in any gear, its just that about the only way to substain a reference point is in 5th gear gooing 65-73.
Old Aug 30, 2007 | 07:40 AM
Timex's Avatar
Timex
Are the bolts in the mounts tooooo tight?
Old Aug 30, 2007 | 07:44 AM
NCCopBikeRider's Avatar
NCCopBikeRider
Maybe bolts tooooo loose?
Ride Em Carry Em
Old Aug 30, 2007 | 07:48 AM
hoz88's Avatar
hoz88
Is the vibration kind of a side to side shake? Thay's what mine was doing, and the top motor mount was loose. Not broken - loose. I had checked it visually and it looked fine, but once I put a wrench to it, it was pretty bad. 10 minutes took care of the problem.
Old Aug 30, 2007 | 09:32 AM
gunrunner's Avatar
gunrunner
I had vibrations in my street glide, dealer found both tires out of balance by over a ounce from factory, after rebalance 90 % was gone. Mine did it at 2500-3k then smoothed out.
Old Aug 30, 2007 | 08:23 PM
harleybuilder's Avatar
harleybuilder
Not trying to highjack the thread. I have a 05 flht that has developed a (almost thumping like) vibaration that i can feel in the floor boards and highway pegs at around 70mph. ( seems like i feel it more on the left side of the bike) Could it be a loose or broken motor mount? I will try pulling in the clutch tomorrow at the vibration speed and see if that changes anything.
Thanks in advance.
JokerWhiskey
Apr 17, 2015 09:14 PM
Viddells
Jun 28, 2010 08:44 PM
QT Hush
Oct 17, 2008 05:30 PM
hdparrothead60
Jun 24, 2008 11:45 AM
joe v
Oct 27, 2006 12:47 AM
