Fuel mileage using Fuelpak????
Old Aug 29, 2007 | 08:06 PM
gdbro4's Avatar
gdbro4
Default Fuel mileage using Fuelpak????
I have an '07 Ultra with 103 Stage 2, SE-255 cams, V&H True duals with Wide Ovals, and Arlen Ness A/C. I have a PCIII now tuned on dyno.I'm getting 29-32 MPG. Is there anyone out there using the Fuelpak, and what mileage are you getting with it?? I just would liketo see at least 38 MPG??!!
Old Aug 30, 2007 | 04:08 AM
lenny's Avatar
lenny
Default RE: Fuel mileage using Fuelpak????
I ride an 07 ultra with the fuel pack. V&H true duals w/the basic slip ons and an AN big sucka ac. Last ride the wife and I went almost 1300 miles thru upper New York down to Niagra Falls. This part of the trip we did not ride any highway and averaged mid forties per gallon. When we left the Buffalo area and headed back to central Ct I rode 460 miles almost all highway and got high thirties and low forties. Very happy with these numbers considering that we were two up with a couple changes of clothing each.
Old Aug 30, 2007 | 05:45 AM
Pastor John's Avatar
Pastor John
I'm averaging low to mid 40's in mixed conditions. '07 Road King, Stage 1 AC, SE Mufflers, FuelPak.
Old Aug 30, 2007 | 07:05 AM
HarleyArcher's Avatar
HarleyArcher
I have a 88" with stage one, true duals, rush exhaust and a fuel pak. I get 40-45 mpg. That is with both higway and city riding. Bryan
Old Aug 30, 2007 | 07:22 AM
streetglide88's Avatar
streetglide88
I've got a 06 SG with a fuel-pakV&H big shot duals and a K&N and I'm gettin 40-45 mpg
Old Aug 30, 2007 | 09:05 AM
Peppa1's Avatar
Peppa1
If you want good gas mileage you should have left off all the high performance mods that you did to the bike. Bikes are no different than cars.... the more you hot rod them the less mpg's you are going to get. It's not rocket science !!!
Old Aug 30, 2007 | 09:20 AM
Garemlin's Avatar
Garemlin
On my 07 I get 39-40mpg around town. We just took a trip to WV and got about 45mpg on the highway. Of course that is alot of mountain highway riding too. I imagine on a flat highway mileage would probably be even better.
Old Aug 30, 2007 | 09:28 AM
Lost1's Avatar
Lost1
Getting 45-48 mpg on EGC with Fuel Pak w/stock 96" & Rush slipons.
Methinks something is outta whack on your bike if your mpg is that low...
Old Aug 30, 2007 | 09:36 AM
jakedog's Avatar
jakedog
Like others I get 40-45 MPG.
Old Aug 30, 2007 | 09:41 AM
dagnabit9's Avatar
dagnabit9
As my sig says, I have an A/N Big Sucker, V/H oval slip-ons, and a Fuel-pak and I consistently get 44-48+ mpg riding 2 up. When riding out here in New Mexico, you'll encounter a diverse mix of mountain and straight flat roads but the mileage doesn't vary that much. I would suspect your mods are the main culprit in your lower mileage - I've hopped up my truck a bit and got lower gas mileage because of it.
