Changin oil
Old Aug 29, 2007 | 09:20 PM
Bagger_Dave's Avatar
Bagger_Dave
Default Changin oil
Changing oil tonight, put plug back in, new filter on, poured 3.5 quarts, just like service manual says. Checked it cold, barely in between the two arrows. Take it for a short ride, get it up to tempature, check it hot, end up adding the other half quart (4 total now ) and it's still a little shy. Is this normal to anyone else?
Old Aug 29, 2007 | 09:35 PM
gordon188's Avatar
gordon188
Default RE: Changin oil
Holds 4 quarts, normal.
Old Aug 29, 2007 | 09:41 PM
Bryan TTM's Avatar
Bryan TTM
read the dipstick....it tells the truth
Old Aug 29, 2007 | 10:01 PM
iclick's Avatar
iclick
I think Bryan is right, because appearently bikes do vary for whatever reason. However, I would say "hot" means really "hot", not just the kind of hot you get from a short ride. When really hot, have it right at the full mark, no more. I don't know about the '06's, but my '07 will barf through the breather when I install four quarts. I have an oil cooler, which may not make a difference since oil probably remains in the cooler during a change, but I'm not sure. I installed 3.5 qts. last time, then added another 8 oz. (total 3.75 qts.), and I haven't had any barfing since. I'll try the same procedure and if it continues the same way I'll settle on that for the future.
Old Aug 29, 2007 | 10:35 PM
StrGlide's Avatar
StrGlide
It's hot enough to check when you burn your fingers pulling the dipstick.
Ooops....maybe I shouldn't wear my fingerless gloves when checking my oil. It's stupid and gay.
Old Aug 29, 2007 | 11:39 PM
drdiesel1's Avatar
drdiesel1
I run 4 quarts in both of my bikes. 1 quart in the trans and 1-1/4 quarts in theprimary.
Old Aug 29, 2007 | 11:53 PM
jdtest's Avatar
jdtest
good
Old Aug 30, 2007 | 07:42 AM
NCCopBikeRider's Avatar
NCCopBikeRider
4 Quarts in the Cop Glide with the Small black filter
Ride Em Carry Em
Old Aug 30, 2007 | 07:47 AM
petemac's Avatar
petemac
On my bike I throw 4 quarts in after the oil change and it's spot on.
Old Aug 30, 2007 | 07:50 AM
SIM's Avatar
SIM
3.5 quarts is meant to be a starting point. Adjust accordingly.
