Problem with WHIM?
Old May 17, 2024 | 09:03 AM
jljohnson1956's Avatar
jljohnson1956
Jessel0001, Do you have the Phone connected to the GTS and your Sena connected to the GTS? OR the Phone connected to your Sena and the GTS connected to your Sena? I have my Phone connected to the GT and my Sena connected to the GT on my '18 Ultra Limited. Mine seems to work fine but I usually ride one-up and don't use VOX.
Old May 17, 2024 | 09:48 AM
mjmanna's Avatar
mjmanna
My 14 Limited has done that since new. Doesn't matter if its a wired connection or using the whim. Only would happen on phone calls. I don't even use the infotainments system anymore. Just use my phone and Sena 20S for call, navigation, and music.
Old May 24, 2024 | 08:10 PM
Jessel0001's Avatar
Jessel0001
6th Gear
i have the Sena connected to the radio via WHIM and the phone connected with the cord to get car play.
I ride two up a lot and the clicking and echo happens on wife’s headset too.
Old May 24, 2024 | 08:12 PM
Jessel0001's Avatar
Jessel0001
6th Gear
when I’m just using the music, the clicking is pretty well drowned out. But the phone is pretty bad. And the intercom too.
Old May 24, 2024 | 08:38 PM
skratch's Avatar
skratch
Originally Posted by Jessel0001
Is there anyway easy I can test to see if its the radio is or the WHIM that is faulty? I was thinking about buying a new WHIM and returning it if it doesn't fix the issue. I just need to check the return policy.
good luck with that. most electronic items are non-refundable. but who knows, you may get lucky.
Old May 29, 2024 | 07:58 PM
Jessel0001's Avatar
Jessel0001
6th Gear
So I just thought of this but I’m not sure how to test it. What if it’s my PTT button that’s faulty and that keeps activating?
i looked at the wiring schematics and it’s CAN BUS so I can’t just disconnect the PTT button that I can see.
Old May 31, 2024 | 01:07 PM
adammarcos's Avatar
adammarcos
It has to be something in the head unit because it doesn't seem to matter what type of headset you use. It's almost like there is a transient voltage in the system. Maybe it's not grounded well?
Old Jun 2, 2024 | 10:26 AM
Jessel0001's Avatar
Jessel0001
6th Gear
unfortunately, it’s looking more like that’s the case. I tried a new whim, same issues. I disconnected the left-hand controls, no change. I traced and disconnected almost every wire underneath the fairing, and it kept on clicking.
I feel that it’s connected to the microphone activation somehow because I can hear my echo in my own headset even when intercom is turned off, side tone is turned off and there’s no other helmets connected.
I think I’m gonna have to bite the bullet and take it to the shop.
Old Jun 2, 2024 | 01:44 PM
klammer76's Avatar
klammer76
My headset does this also on my 2021 RGS with whim and the HD 50S headsets but only when the passenger is along and her headset is activated. Solo it's not an issue this year (did it intermittently last year). Her headset works fine.
Old Jun 3, 2024 | 05:59 AM
Jessel0001's Avatar
Jessel0001
6th Gear
Did you ever figure out what was causing it?
