96 Engine Build Questions
Old May 13, 2024 | 02:53 PM
acsbmx_1's Avatar
acsbmx_1
Stage III
Default 96 Engine Build Questions
I am in the process of building out an 08 96" engine and have some questions relating to this. I currently have Woods TW-222 cams, Woods Lifters, Fuel Moto pushrods, SE Comp Sprocket, stiffer clutch spring, 2:1 Exhaust and TMax ECU.
My questions are as follows:
1. What would the benefit be of me doing a big bore 110 kit for the cylinders? Would I even see any improvement and if so, how much?
2. Is a port/polished head required to take advantage of the 110? Or would new heads with port/polish, new valves and springs be needed?
3. Would new cams be needed going this route?
4. What if just heads were installed? Would that do anything without the full Stage 3 kit?
All in all I'm just trying to figure out the best method to move forward and not spend an arm and a leg on things that aren't necessarily going to make a noticeable or dramatic difference.
Thanks.
Old May 13, 2024 | 04:57 PM
svarnster's Avatar
svarnster
it all has to work in unison.
Old May 14, 2024 | 04:42 AM
xcbullet's Avatar
xcbullet
You didn't mention miles on bike. Are you assembling it?
Old May 14, 2024 | 08:32 AM
acsbmx_1's Avatar
acsbmx_1
Stage III
There are currently around 43k miles on the bike.
Old May 14, 2024 | 10:10 AM
hattitude's Avatar
hattitude
Thanks.
As svarnster pointed out above, the aftermarket parts need to compliment each other, and work in unison.
You could throw a bunch of high quality parts together, but end up with a dog.
It appears you already have Woods cams and FuelMoto pushrods... Those are both staples of FuelMoto packages.
In your shoes, I would call FuelMoto. Tell them what you have, what your goals are..... see what they suggest.
If not FuelMoto, the shop of your choice. See what they recommend. Performance shops will have the experience to know what works well together...
Good luck with your decisions..
Old May 14, 2024 | 10:25 AM
acsbmx_1's Avatar
acsbmx_1
Stage III
Thanks for the reply. I will reach out to a shop as well.
Old May 14, 2024 | 11:35 AM
xcbullet's Avatar
xcbullet
I would do a 103 with ported heads but I like small changes Then next time go 107 after that maybe a 110.
Celticson
Twin Cam Motors
52
Jan 2, 2022 06:34 PM
kevinb62
Engine Mechanical Topics
14
Dec 27, 2021 12:23 AM
rons73
Dec 14, 2018 12:49 PM
emerican19
Feb 10, 2014 10:58 AM
Bluzmn59
Aug 8, 2007 09:37 AM
