confused on clutch
Old Aug 30, 2007 | 05:34 PM
relli's Avatar
relli
Default confused on clutch
im confused on this clutch adj thang. therse two adj's. i adj my cable today and all the nasty slop is gone and all is well. maint schd shows chk every 5k. how do ior would i recognize the need to adj the clutch pak (as i call it) behind the derby???slipping of course would be a tip off but by time its slipping its prob too late. i run amsoil and change the trans/primary every 10k
Old Aug 30, 2007 | 06:02 PM
cwilks's Avatar
cwilks
Default RE: confused on clutch
The first adjustment (at the lever) will dictate the secondary one (behind the derby cover)........after you have adjusted it a couple of times at the lever (to take slack out, which indicates wear)I would adjust at the clutch pack
MarcV125
Jul 7, 2013 11:31 AM
mooseatk
Apr 16, 2013 07:08 AM
JockWhisky
Feb 17, 2011 08:06 AM
UglyLou
Jun 25, 2008 03:46 PM
lou1
May 19, 2008 03:00 PM
