Tx smitty! Is the Clymer really that bad?
Im.not a "mechanic" so I wont be using it to tear down my motor, but it did help in replacing my fuel pump and other assorted minor jobs.
I'll take a look at the HD one.
As for codes.......if I DONT see check engine is it safe to assume I'm good?
And if I DO see it, acceas the code by pushing side button on dash?
Problem with Clymer and Haynes is they cover several years. They cover the common stuff but make you go to section a for 95-98 figure one then a different section for 99-2000. You have to jump around to your proper year and gets confusing and could cause mistakes.
Yeah......I noticed that. What you say makes sense.
So the Harley manual is year/model specific.
I called HD a while ago.......parts guy said manual will rum me about $160 or more!
YIKES!!
YIKES!!
Yeah, but theyre worth it if you work on your bike.
