Oil Change issue
Old Aug 31, 2007 | 07:59 AM
starman's Avatar
starman
Default Oil Change issue
Hey all:
First let me say I've changed oil on many bikes. However, this is my first Harley. I changed the filter and the oil. I put the bike on my sears jack. However, I was able to put in only 3 qts. and I am at the middle mark on a cold check. According to the manual it is full like this on a cold check. I did check theoil level on the Jiffy Stand. Did I need to have the bike in a different position to drain the other quart (manual says capacity with filter is 4 qts) it was level on my sears lift. I was only able to put in 3 qt without what I would think would be overfilling. I always put in less at first on any oil change to check the level and fill the remaining as needed.
What if anything did I do wrong?
Thanks for the help.
Old Aug 31, 2007 | 08:09 AM
Xchief's Avatar
Xchief
Default RE: Oil Change issue
Not sure about your 07 but my 05 oil is checked on the jiffy stand . Check your manual or somebody here with an 07 will let you know.
Also run it for afew seconds, shut it down have a cold one while you wait and then recheck level. (this should let the filter fill up).
You are right that cold level should be half way on the stick, but on mine its checked on the stand.
Old Aug 31, 2007 | 08:10 AM
fatboylust's Avatar
fatboylust
Typically some oil hangs in the filter (not easy to drain the filer) and some hangs in the engine pluming so once drained it usually takes about 3.5 quarts to refill. If the bike wasn't fully warmed up you'll get less out too. There are expensive devices you can buy that allow 100% change by dumping oil from the return line while the bike is running until the oil runs clean.
FBL
Old Aug 31, 2007 | 08:11 AM
Bryan TTM's Avatar
Bryan TTM
JBWeld
Old Aug 31, 2007 | 08:22 AM
NICK56's Avatar
NICK56
GEEZUS just put the 4 qts in and ride the bike!
If u put 5 qts in it wouldnt matter !
Old Aug 31, 2007 | 08:23 AM
Bryan TTM's Avatar
Bryan TTM
exactly...another stupidass question....done it before huh
ORIGINAL: NICK56
Old Aug 31, 2007 | 08:59 AM
starman's Avatar
starman
ORIGINAL: Bryan TTM
ORIGINAL: NICK56
No actually another stupidass answer. Anytime you want to compare knowledge let me know Putz
Old Aug 31, 2007 | 09:16 AM
cwilks's Avatar
cwilks
This should be good [sm=popcorn.gif]
Old Aug 31, 2007 | 09:22 AM
Mikind7's Avatar
Mikind7
[sm=popcorn.gif]
Old Aug 31, 2007 | 09:23 AM
starman's Avatar
starman
ORIGINAL: cwilks
Not at all. I'm just tired of As*holes like the above ruining these boards with their "stupid ***" responses. It was a legitimate question and I was looking for a "real" answer not some smart *** JB Weld answer. I usually find that the ones who answer like that on any boards don't know Sh*t from Shinola. Boards are supposed to behere in my opinion to help each other. As I said it's only just a matter of time on any board that the board "as*holes" have to chime in. Oh, well.
If anyone doesn't like a topic or feels it is beat to death they don't have to read it.
