historical codes
Old Jul 19, 2024 | 01:37 PM
Bushy's Avatar
Bushy
Question historical codes
2020 ultra limited question
historical codes show up after a ride engine light on clear codes engine light off...
any ideas??? PS I always clear codes before riding
Old Jul 19, 2024 | 02:13 PM
WONKEY's Avatar
WONKEY
What codes are they. that is very important information and a good place to start.
Old Jul 19, 2024 | 03:12 PM
Keithhu's Avatar
Keithhu
This is a very strange habit.
Old Jul 19, 2024 | 08:59 PM
hattitude's Avatar
hattitude
We need to know what the codes are...???
Are they always the same codes, or do the codes always vary..?
I am unaware if things changed with the M8 engines.... but....
On the Twin Cams, the check engine light only stays on with a current code. It comes on, then goes off, if there is a historic code. If you don't manually clear a historic code, it will clear itself after 40 (I believe that is the magic number) drive cycles without the code becoming active again.
If you have to clear codes after every ride, then you either have active codes, or a seriously intermittent code that could be a warning that an issue is brewing...
The codes that you are clear and then they return, are an important piece of information...
Not all codes are necessarily bad...
For example, when I remove my Tour Pack, until I hook it up again, there will always be a couple active codes... They have to do with the rear speakers and passenger stereo controls. Obviously, I don't care about those codes, because I know they are active due to removal of the tour pack.
If you want educated opinions, you need to give us more info....
The codes in question and any recent work done to the bike would be a good start....
Old Jul 20, 2024 | 09:37 AM
Bushy's Avatar
Bushy
I know they are historical but yes I checked everything,... battery postive was slightly loose . we will see it this was the fix
Old Jul 20, 2024 | 12:32 PM
skratch's Avatar
skratch
if you are clearing the codes before every ride, and then you are getting codes, how can they be historical?
Old Jul 20, 2024 | 07:00 PM
Max Headflow's Avatar
Max Headflow
Because the code is intermittent? There long enough to set but clears after time..
Vet0370
Jun 3, 2021 08:30 PM
Thekid338
Jul 24, 2017 07:42 PM
chizman
May 15, 2011 04:35 PM
tekeum
Jul 14, 2010 08:55 PM
