Shift issue
Old Jul 21, 2024 | 05:23 PM
piasspj's Avatar
piasspj
Loosen the cable adjustment in the middle of the cable. Adjust the set screw/nut inside the derby cover (Thie is the important one and I'm sure there are directions in many forums and on you tube). Then redo the mid cable adjustment.
Old Jul 21, 2024 | 05:38 PM
Highway Handler's Avatar
Highway Handler
Originally Posted by 03_FatBoy
Ok guys, I jacked the bike up and checked it out. The clutch was out of adjustment. Now I have another question, how can adjust the cable so my friction zone is earlier in the release of the lever? Seems like it's on the back side of the release. Thanks!!
https://www.hdforums.com/forum/prima...-the-book.html
This should help.
Old Jul 22, 2024 | 11:59 AM
03_FatBoy's Avatar
03_FatBoy
Originally Posted by Dano523
Did you fill the primary with fluid, with bike level on lift, to this point?
Fluid higher than that in the primary, is going to cause striction problems between the plates,and clutch will never release correctly.
Also, same problem can happen if the fluid being used, is to thick and to the correct level.
Fluid lower than that point, then the discs are at the mercy of the reduced amount of fluid being thrown up in the primary to keep the discs lubed, or can end up with heat problems on the discs.
So oil level in motor, bike on jiffy stand,
primary and trans fluid levels, bike level on stand.
And don't trust the manual on amounts in the primary,since have seen a few of them wrong, so use the above the diagram for primary fluid level and again, bike level, not on jiffy stand.
And for good measure, what fluids used for three hole change, and weights of each.
While I was in there. I checked the primary oil. I put 1 quart in it when I changed the oil, and it looked a little low?
Old Jul 22, 2024 | 07:13 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Just curious, you do know the clutch pack and cable are to be adjusted on a cold/room temp. engine primary. I realize the dealer shops don't wait for a cold engine, but they must have a "secret" way on the clutch pack to compensate for the heat.
Old Jul 22, 2024 | 11:54 PM
btsom's Avatar
btsom
Probably there is nothing wrong, but that doesn't mean you won't benefit from a full and proper clutch adjustment. On occasion i will stop before I have had a chance to down shift into first before the bike is stopped and the transmission won't go into the next gear. Try easing the clutch lever out to the start of the friction zone while holding pressure on the shift lever. The transmission will rotate slightly and the dogs in the next gear will line up and the transmission will drop into that gear. Then pull the lever back to the grip. Often I must repeat that process several times until I get it into low. Most of the time that process isn't necessary. It just seems to be the luck of the draw as to whether you can shift while not moving or must drag the clutch slightly as described above to shift into the desired gear.
RDKG2
2014-2024 Touring Models
Jul 21, 2024 05:10 PM
Caddo
Sep 20, 2015 09:57 AM
clyles
Mar 22, 2014 02:34 PM
Badhd05
Jul 22, 2012 12:12 PM
Flhrhog
Jun 24, 2012 08:01 PM
