Bike wont shift
Old Jul 8, 2012 | 12:13 AM
Badhd05's Avatar
Badhd05
Stage I
Default Bike wont shift
On a hot day you can ride and it is fine but if you stop and let it set a little then go to ride the bike wont shift, its fine on a cool day anyone have any ideas what it might be Thanks
Old Jul 8, 2012 | 08:16 AM
Alleyn's Avatar
Alleyn
What model, might be helpful... Do you mean the gears won't change when on the road, or you can't get into gear when stopped?
Old Jul 8, 2012 | 01:26 PM
_Gir_'s Avatar
_Gir_
If you're at a stop, let the clutch out a little and you'll hear a quiet thunk. Pull the clutch back in and you should be able to shift to the next gear.
Old Jul 22, 2012 | 12:12 PM
JRK5892's Avatar
JRK5892
Sounds like a clutch adjustment is needed does it make any sounds? Also check that the shifter arm is not bent and touching anything
DreadShoes
Harley-Davidson Street
Jun 7, 2019 01:03 PM
Chris Scott
Jun 25, 2017 06:41 AM
Cycopath
May 15, 2010 06:41 PM
michaelbarry
Mar 30, 2008 08:20 PM
glebo
Aug 7, 2007 08:58 AM
