Another comp sprocket issue
Old Aug 19, 2024 | 09:17 PM
ahhlou's Avatar
ahhlou
A few good options are available. I have run the SE comp and I am sure the Baker is a good one. My choice the last time I needed one was the Dark Horse Man-O-War sprocket.
The comp is the first item in the power train to take a beating from the crank, so don't cheap out on it...
Old Aug 19, 2024 | 09:25 PM
TriGeezer's Avatar
TriGeezer
Seriously?????
Old Aug 19, 2024 | 11:31 PM
Dano523's Avatar
Dano523
the problem is the comp design of the Harley, did not keep up with the increase of the power that the newer motors have (after the evo) , that the comps did keep up with..
Watch,
Old Aug 20, 2024 | 01:05 AM
matt_eglide's Avatar
matt_eglide
Originally Posted by flhf150
Hi all, A buddy of mine trailered his bike over to my place. It's a 2007 flhx(street glide) he said it made it made a banging noise and he took it right back home(only a block away). I pulled off the primary cover and found the comp sprocket was in 2 pieces.The cup that the comp spring pack sits in, is attached to the stator rotor. The cup is what broke. Any one see this before?
I have a used-takeoff rotor I’ll donate to the cause if he wants to pay for the ride from SoCal…
Old Aug 20, 2024 | 06:06 AM
Rounders's Avatar
Rounders
Watch,
gkGQrTt_cRY
I am curious what the big evos did for comps and any issues?
Never trust a guy who calls himself doc. I've watched that video, I think he gets a few of his years wrong and such. He is a harley suck up.
Old Aug 20, 2024 | 06:50 AM
flhf150's Avatar
flhf150
Originally Posted by MURPHCC1
Did the BAKER comp on mine at 40k miles.......NO problems at all!
I installed the Baker in mine also. I changed the chain tensioner to Hayden.A lot quieter now.
Old Aug 20, 2024 | 06:54 AM
flhf150's Avatar
flhf150
Originally Posted by Rounders
I was trying to figure out rotor thing. Some of the descriptions say need a new rotor I thought. Last time primary was off I considered. Around $300ish then. But then I thought you needed a rotor$$
Is your buddy a hard rider? I like to cruise fast, but I am wuss at taking off. LIke to hit the on ramp fast, but I am no good at holeshots.
No he's not a hard rider. At least when I ride with him. LOL I'm taking a ride to the harley dealer today and talk to the parts manager. I'm pretty good friends with him. I have the part #'s from Ohio HD.
Old Aug 20, 2024 | 09:45 AM
Ohio HD's Avatar
Ohio HD
Just for accuracy's sake, here is the correct image of the parts in the 40100061 kit. The plastic scoops are shown. The first image was the early SE compensator, this one is the current model.
Old Aug 20, 2024 | 09:58 AM
Rounders's Avatar
Rounders
I took Hayden out. Seemed way to tight
I had bearing fail 25k, put in Hayden. Another failed around 50, put baker bearing in, that failed too.
Put Harleys next version of tensioner in.
I think I would be tempted to go manual if fails again
Old Aug 20, 2024 | 12:59 PM
TriGeezer's Avatar
TriGeezer
Put in a baker, and be done with it.
