‘02 RoadKing pulling DTC’s
Old Aug 22, 2024 | 09:46 PM
Lancealex's Avatar
Lancealex
Default ‘02 RoadKing pulling DTC’s
The “Off/Run” switch on the right handlebar I switch to “Run”.
then I hold the “trip” button down and turn the Ignition switch to “On”.
the display shows - d01clr, I click again, -d02clr, I repeat this all the way through
-d09clr, and click again and “PPU” comes up. Then back to repeat all again.
Im assuming the ‘d01clr’, the ‘clr’ means clear. I can’t find info on
the “PPU”. Anyone else have these come up?
Old Aug 22, 2024 | 10:07 PM
Rounders's Avatar
Rounders
Do you know the alphabet? what model do you have? My understanding is 2002 carbed bikes can pull codes from dash but not delphi
Old Aug 22, 2024 | 11:13 PM
Lancealex's Avatar
Lancealex
Its a 2002 FLHR 1550, mikuni hsr 42 carb.
Old Aug 23, 2024 | 06:58 AM
Rounders's Avatar
Rounders
I think you are right about clr. I also think PPU is normal plus some kind of long number You can't get all the codes in that year. You have to do a paper clip trick to and get a more code type reading. Its in the electric manual. and probably on the internet.
Are you just looking, or having problems? Do you have a code up right now you are trying to read?
Old Aug 23, 2024 | 10:13 AM
Lancealex's Avatar
Lancealex
I was having stalling issues, abrupt stalling while riding. Then it wont start back up for 5-10 minutes. The last time it stalled i tried on and off for 30 minutes and it wouldn't start. I’ll have to try jumping the 2 terminals on the DTC plug. I don't think I have an ‘engine’ light on the speedometer to flash codes though, just an ‘oil’ light.
At first I thought the float bowl wasn’t letting fuel in, but when it stalls it doesnt putter out like it was running out of gas, it just cuts off.
Old Aug 23, 2024 | 04:47 PM
Lonewolf176's Avatar
Lonewolf176
Sounds like crank position sensor, if it sits for 10-30 minutes and then starts.
Old Aug 23, 2024 | 04:53 PM
Rounders's Avatar
Rounders
You have all the lights everyone else has.
So the bike cranks over, but won't start? Carry a spark plug. Stick it on quick and see if you got spark. Leave plugs in. Though the problem is you are riding a bike you can't trust, and I sure would not want to go far.
It is a 20 year old bike. Myself, I would not be afraid to throw parts at, because it is 20 years old. CPK is good start , coil is too.
My 2001 FLHR is on the 3rd coil with 90k miles.
NM Pan-shovel
Panhead
Nov 11, 2022 04:00 PM
Deborah Scott
Jul 21, 2013 12:36 PM
onemyndseye
Jan 7, 2012 09:55 AM
rjames
Oct 10, 2010 10:25 AM
Sketz
Sep 3, 2008 08:22 PM
