Aiming BD LP6 headlights
Old Sep 24, 2024 | 02:54 PM
Grousehunter's Avatar
Grousehunter
Default Aiming BD LP6 headlights
For those of you that run these lights where do you have them “aimed”? It has been suggested that I aim them “down” about 5 degrees. I started there then went to 4 degrees. The hi beam “hot spot” is only about 20 feet in front of my bike. This makes me think I should get rid of the “down” angle. OR….do you find that the hi beams “hot spot” is not really needed and sufficient light is achieved with the hi beams on but pointed a bit at the ground?
These lamps are are mounted to a ‘23 CVO Anniversary RG. Thanks much.
Old Sep 24, 2024 | 04:50 PM
Ultra103's Avatar
Ultra103
On all vehicles - 25' from a vertical surface, vehicle parked on a flat, level surface. Measure from the ground to the center of the headlight, place a piece of tape or mark a line at that height on the vertical surface 25' away. Aim the low beam a couple of inches below this line.
On vehicles with dual headlights, the right side lamp can be on the line, the left should be a couple of inches lower.
Pointyhairboss
2018+ Softail Models
11
Sep 5, 2024 05:41 AM
UltraV
Screamin Eagle CVO Models
Oct 9, 2022 11:59 AM
memphisharley
Sep 19, 2021 10:54 AM
al_ferguson01
Jan 20, 2020 12:27 PM
cardboard
Jan 30, 2015 10:19 AM
